Elastic Collisions angle 90 degrees
The angle between the velocities of two equal mass objects in a non-head-on, perfectly elastic collision is always 90 degrees when one object is initially at rest. This conclusion is derived from the principles of conservation of momentum and kinetic energy, as demonstrated in classical mechanics. Specifically, the momentum of the moving object is completely transferred to the stationary object along the collision's normal direction, resulting in perpendicular velocities post-collision. This phenomenon is applicable in various scenarios, including billiard ball collisions, where rotational kinetic energy also plays a role.
  • Understanding of conservation of momentum in elastic collisions
  • Familiarity with kinetic energy conservation principles
  • Basic knowledge of frame transformations in physics
  • Concept of impulse and reaction forces in collisions
  • Study the derivation of momentum conservation in elastic collisions
  • Explore the implications of rotational kinetic energy in billiard ball dynamics
  • Learn about frame transformations and their effects on collision angles
  • Investigate the mathematical proofs found in classical mechanics literature, such as Goldstein's book
Physics students, educators, and professionals interested in mechanics, particularly those studying collision dynamics and energy conservation principles.
yitriana
Why is the angle between products in non head on, perfectly elastic collisions always 90 degrees?
Very good question!
I unfortunately do not know why :frown:
I have tried proving it with principles of conservation of momentum, conservation of energy, impulse and forces, but still cannot get any luck.
My guess is that on non head-on collision involving spherical objects, (and as long as one of the object is initially stationary) the force that the moving object (1) exerts on the stationary one (2) is directed towards the center of (2).
The reaction force that (2) exerts on (1) is equal in magnitude with the action force and thus is proportional to the initial momentum of (1). (impulse principle)
With this, collision is such that the reaction force will always cause the initial momentum of (1) to change direction making a resultant that has 90 degrees angle with the direction of (2). This may be able to be proven by solving energy conservation (just a guess)
i attached a picture to demonstrate my idea
Hope it is right and helps
I think this is only true for two equal masses. You can get there like this:
- For a 1D elastic collision of two equal masses A and B with B initially at rest, you can show (via momentum and kin.energy conservation) that the momentum of A will be completely transferred to B.
- For 2D/3D the above still holds along the collision's normal direction, along which B moves after the collision. Since the momentum along that direction is completely removed from A's momentum, A is left only with the momentum perpendicular to it.
- Obviously: If this holds true in the frame of reference where B is initially at rest, it has to be true in every frame, because angles are preserved under frame transformations.
The recoils of the two products are always 90 degrees apart if both incident masses are the same. It is proved somewhere in Goldstein's book on Classical Mechanics. Both masses have to be equal, and one has to be stationary before the collision.
Let me try to 'show' it:
Consider two particles of same mass and one of them approach the other (not necessarily head on) with one of them originally at rest.
The total momentum before and after the collision will thus be:
p1 = p'1 + p'2
The sum of the kinetic energy of the center of masses of the particles is also conserved for elastic collisions. The relation p2/2m = T can be used to express the conservation of energy for the collision:
p12/2m = p'12/2m + p'22/2m
Thus p12 = p'12 + p'22
The above equation implies that p'1 and p'2 must be perpendicular to each other so that the sum of their squares give another square p12 because of the Pythagoras Theorem, provided that initially they are not head on. If it is a head on collision, then the momentum of the approaching particle will be zero after the collision since there cannot be any momentum in the direction parallel to the direction of the momentum of the particle originally at rest. Otherwise it would not be head on in the first place.
This moving off perpendicularly thing seems to only be possible from the frame of reference where originally one of the particles are at rest. I'm not sure about angles being preserved under a frame transformation... because if I consider relative to K' the velocities are perpendicular, but relative to K I have to add the relative velocity between K' and K and this would imply that relative to K the velocities are not perpendicular. I don't know if I'm correct on this point.
You are correct. Just imagine what the velocities would be relative to an observer who is flying past at a speed, in the original frame, that is 100 times greater than either of the particles' speeds.
Therefore...
...not true.
Yeah you're right, angles between velocities are of course frame depended. What was I thinking. :redface: So it's 90° only when one mass is at rest. Still useful in billiard.
I used to believe that billiad ball collisions were ideal two-body collisions. But 2/7 of the total kinetic energy of a billiard ball is rotational, not linear (translational) kinetic energy, because their moment of inertia is 2/5 mR2.
  • · Replies 20 ·
  • · Replies 17 ·
