Elastic Collisons (Conservation of Ke and P)
  • Thread starter Thread starter notagenius08
    Elastic
A proton collides elastically with a carbon atom, which is 12 times its mass, and the problem involves calculating their speeds and directions post-collision. The conservation of kinetic energy and momentum equations are utilized, leading to a system of equations. The discussion highlights the difficulty in solving these equations, particularly in avoiding circular reasoning. A suggested method involves substituting values from one equation into another to simplify the problem without resorting to quadratic equations. The conversation emphasizes the importance of using independent equations for accurate results.
notagenius08
A proton is traveling to the right at 2.0x10^7 m/s. It has a head on perfectly elastic collision with a carbon atom. The Mass of the Carbon atom is 12 times the mass of the proton. What are the speed and direction of each after collision?
Ke=1/2M*V^2
P(momentum)=M*V
p=proton
c=carbon
After the collision:
1/2MpVpf^2 + 1/2McVcf^2=1/2MpVp^2
MpVpf+McVcf=MpVp
Solved for:
Vcf=Vp-Vpf/12
Vpf=Vp-12Vcf
Vcf^2=Vp^2-Vpf^2/12
Vpf^2=Vp^2-12Vcf
I've tried a few times but can figure out how to solve the rest of the equation. Every time I make a substitution I get MpVp=MpVp.
Which I already knew, so I guess my algebra is a bit crap.(spelling too!)
What is the next step?
Thanks to anyone that helps.
I'll walk you through one way to solve:
You have four equations.
1) Take the first (for Vcf), square it to find Vcf^2.
2) Now plug it into the third equation instead of Vcf^2 (on the left side).
3) This result now needs to be reorganized so everything is on the right side or left (so one side is zero.
4) Note: the above result is likely a quadratic equation with the unknown "x" being Vpf.
5) Solve the quadratic equation for Vpf.
6) now plug that back into any of your original four equations to find Vcf.
why did I chose 1 and 3?
they come from different original equations (momentum conservation and energy conservation). These equations are therefore "independent" of each other. You can't chose 1 and 2, or 3 and 4 for the process... but you could have also chosen 2 and 4, or 1 and 4 or 2 and 3.
Thanks for your help.
It actually does simplify down, and so you don't have to use the quadratic equations.
Thanks again for your help!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
