Electr. Engineering - Digital Sig. Processing
5 replies · 3K views
DefaultName
Determine if the CT systems are 1) casual or uncasual 2) memory or memoryless.
Definitions:
Casual: If for any time t1, the output response y(t1) at time t1 resulting from input x(t) does not depend on the values of the input x(t) for t > t1.
Memory: If the output at time t1 depends in general on the past values of the input x(t) for some range of values of t up to t=t1.
[tex]x(t)[/tex] is random input and [tex]y(t)[/tex] is the output of [tex]x(t)[/tex]
For Eq1:
[tex]y(t) = |x(t)| = \left\{ \begin{array}{l}<br /> x(t)\; \mathrm{if}\, x(t) \geq 0 \\<br /> -x(t)\; \mathrm{if}\, x(t) < 0<br /> \end{array}\right.[/tex]
I said this system is CASUAL and MEMORYLESS.
  • Casual - because at time t, y(t) will depend only t from the input function x(t), not some other arbitrary t value.
  • Memoryless - because the outputs at time t do not depend on previous inputs.
For Eq 2:
[tex]y(t) = \int_0^t\lambda x(\lambda)d\lambda[/tex]
I said this system is CASUAL and has MEMORY.
  • Casual - because at time t, it doesn't really depend on the future. It only depends on the past, so I'm guessing casual. *This I'm not too sure about*
  • Memory - because the outputs at time t do depend on previous inputs since youre taking the integral from 0 to time t. *I'm almost sure about this one*
Both your answers look good to me. By the way, it's "causal" not "casual". :wink:
Hahha, I just realized that. Wow.
Thanks tho.
Now, Eq1 is obviously linear, but when I graph eq2, it seems to be nonlinear... does that make sense?
Yes.
- Warren
chroot said:
Yes.
- Warren
is it because when you take derivatives and integrals, the terms will become nonlinear
also, in the one DefualtName posted, for equation 2, would that be a time varying or time invariant one. i would say varying because the actual output will be different from the input
