What is the Net Force on a Helium Nucleus Due to Proton and Electron Charges?
The net force on a helium nucleus due to a proton and an electron is calculated using Coulomb's law. The proton is positioned at x = 1.6 nm and the electron at y = 0.85 nm. The calculated forces are F_pHe = -0.180i nN from the proton and FeHe = 0.638j nN from the electron. The confusion arose from incorrect unit conversions, specifically using millimeters instead of nanometers, leading to significantly smaller force values.
  • Coulomb's Law for electrostatic force calculations
  • Understanding of charge units (e.g., elementary charge e)
  • Knowledge of unit conversions, specifically between nanometers and meters
  • Basic vector addition for force components
  • Review Coulomb's Law and its applications in electrostatics
  • Practice unit conversions, particularly between nanometers and meters
  • Learn about vector addition in physics for combining forces
  • Explore the concept of electric fields and their relation to forces on charges
Students studying physics, particularly those focusing on electrostatics, as well as educators looking for examples of force calculations involving charged particles.
Whatupdoc
A proton is on the x-axis at x= 1.6nm. An electron is on the y-axis at y=0.85nm. Find the net force the two exert on a helium nucleus (charge + 2e) at the orgin.
there's a solution from the book, but i don't really understand it:
k = 9X10^9 N*m^2 and e=1.6*10^-19
Coulomb force of the proton on the helium nucleus is F_pHe = k(e)(2e)(-i)/(1.6mm)^2 = -0.180i*nN (i get 1.8X10^-28 instead)
for the y:
FeHe= k(-e)(2e)(-j)/(.85nm)^2 = 0.638j nN (i get 6.377 X 10^-28)
the answer would be -0.180i*nN + 0.638j nN right? i just don't know why my numbers are so small
Coulomb force of the proton on the helium nucleus is F_pHe = k(e)(2e)(-i)/(1.6mm)^2 = -0.180i*nN (i get 1.8X10^-28 instead)...
The distances given was in nm-s (10^-9 m) but you used mm-s (10^-3). or you even have forgotten that 10^-3, too.
ehild
(9X10^9 N*m^2)(1.6*10^-19)(2(1.6*10^-19))(-i)/(1.6mm)^2 = 1.8X10^-28
right? i did use 10^9
no, for the distance you just used 1.6 m .
enter the distance into your calculator as (1.6E-9 [m])^2
and be sure to use the EXP button (or EE button) ,
NOT the ambiguous sequence / 1.6 x 10 ^-9 ^2 !
