Electric field 0.1mm above charged plate.
The discussion centers on calculating the electric field strength above a charged copper plate measuring 0.08x0.08 meters, with a total charge of 9*10^9 electrons. The correct formula for the electric field above a single charged plate is E = n/2ε₀, where n is the charge density and ε₀ is the permittivity of free space. The initial calculation yielded an incorrect electric field strength of 25423.72 N/C due to the use of the wrong formula for a single plate. Attention to significant figures is also crucial in reporting the final answer.
  • Understanding of electric charge and its quantification
  • Familiarity with the concept of electric fields
  • Knowledge of the formula for charge density (n=Q/A)
  • Basic grasp of the permittivity of free space (ε₀)
  • Review the derivation of the electric field formula for a single charged plate (E = n/2ε₀)
  • Learn about significant figures in scientific calculations
  • Explore the concept of charge density and its applications in electrostatics
  • Investigate the differences between electric fields produced by single plates versus parallel plates
Students studying electromagnetism, physics educators, and anyone involved in electrostatics calculations.
megr_ftw
A thin 0.08x0.08 meter copper plate is charged with 9*10^9 electrons. What are the strength and direction of the electric field 0.1mm above center of the top surface of the plate.
n=Q/A
E=n/E_0
I found the linear charge density to be 2.25*10^-7 c/m^3 from the first equation above. I multiplied the number of electrons by the charge of a single electron and divided by the area.
Next I took the linear charge density and divided it by epsilon_0 to get a final charge of 25423.72 N/C.
I plugged this into webassign but it says that's wrong? could someone check this for me because I swear this is the right way to go about this problem
thanks
megr_ftw said:
E=n/E_0
That equation is for a pair of oppositely-charged plates.
For a single plate, it's
E = n/2εo
They might want you to watch the number of significant figures in the answer you report, too.
Other than that, things look okay to me.
  • · Replies 18 ·
  • · Replies 26 ·
  • · Replies 58 ·
  • · Replies 16 ·
