Electric Field and Charge of a Capacitor
The discussion centers on calculating the electric field and charge of a capacitor in a cathode-ray tube (CRT) scenario. The dimensions of the deflection plates are specified as L = 13 cm, d = 4 cm, and the gap h = 2.5 mm. The change in momentum of the electron is given as < 0, 5.60e-17, 0 > kg m/s, leading to the calculation of the electric field strength, which is determined to be E = 350,000 N/C. The charge on the upper plate is calculated to be Q = 5.077e-14 C using the formula Q = sqrt(permittivity * F * A).
  • Understanding of electric fields and forces, specifically F = qE
  • Knowledge of impulse and momentum concepts
  • Familiarity with capacitance calculations
  • Basic understanding of the geometry of capacitors
  • Learn about the relationship between electric field strength and potential difference in capacitors
  • Study the derivation and application of capacitance formulas for parallel plate capacitors
  • Explore the implications of charge distribution on electric field strength
  • Investigate the role of permittivity in electric field calculations
This discussion is beneficial for physics students, electrical engineers, and anyone involved in the study of electromagnetism and capacitor design.
Squall
In a cathode-ray tube (CRT), an electron travels in a vacuum and enters a region between two "deflection" plates which have equal and opposite charges. The dimensions of each plate are L = 13 cm by d = 4 cm, and the gap between them is h = 2.5 mm.
During a 0.001 s interval while it is between the plates, the change of the momentum of the electron is < 0, 5.60e-17, 0 > kg m/s.
What is the electric field between the plates?
What is the charge (both magnitude and sign) of the upper plate?
E is pointing upwards towards the upper plate from the bottom one.
Impulse = Force * Time
F= q*Enet
E= (Q/A)/(permittivity constant) "per"
F = <0,5.6e-17,0>(kg*m/s) / .001(s)
Enet = F/Q
Enet = (Q/A)/"per"
F/Q=(Q/A)/"per"
Q=sqrt("per"*F*A)
Q=sqrt(8.854e-12(C^2/Nm^2) * <0,5.6e-14,0>(N) * .0052(m^2)
Q=5.077e-14C
Well this is my attempt to find the charge and it seems I am doing something wrong, can you please point me in the right direction.
Thank You
Calculate the field strength.
With the field strength and the geometry given, calculate the potential difference (voltage) across the plates.
Calculate the capacitance of the plate arrangement.
With the capacitance and the voltage across it, find the charge.
I am sorry but can you tell me how I would go about calculating the strength of the field. I assumed you would have to know the charge first to figure out the strength.
Tell me if I'm headed in the right direction since we are dealing with an electron I know the charge therefore should be able to figure out the electric field using the F=qE formula.
|F|= 5.6e-14N
q= -1.6e-19C
E=350,000 N/C
Thank You, I figured it out
  • · Replies 18 ·
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 26 ·
