Electric Field Approximation for Linear Quadrapole Problem
  • Thread starter Thread starter Old Guy
    Linear
8 replies · 3K views
Old Guy
Given the following charges, all on the x-axis:
-q at x=-d
+2q at x=0
-q at x=d
Show that the electric field at a point (x,y) = (0,r) (ie, on the y-axis a distance r from the origin) is approximately:
[tex]\frac{3qd^2}{4\pi\epsilon_{0}r^4}[/tex]
We were asked for an approximation, but it seems to me that an exact solution is relatively straightforward. The direction of the field from the positive charge would be along the y-axis. The field resulting from the negative charges would be from y=r toward those charges, but the x-components of those fields would cancel. Consequently, shouldn't the field simply be the field produced at r by the positive charge, minus the y-components of the fields produced by the negative charges? Am I missing something?
You're right, the exact solution is straightforward--but it's messy. Start by writing down the exact answer and showing that it reduces to that simple approximation when R >> d.
Right, and for that I got [tex]\frac{2q}{4\pi\epsilon_{0}[\frac{1}{r^2}-\frac{r}{(r^2+d^2)^(\frac{3}{2})][/tex]
I understand the concept of taking r>>d, but don't see any way with the above equation that gets either d^2 or a 3 in the numerator, or r^4 in the denominator.
And thanks for your help!
[tex]\frac{2q}{4\pi\epsilon_{0}[\frac{1}{r^2}-\frac{r}{[(r^2+d^2)^(\frac{3}{2})]][/tex]
Well, I'm having trouble getting the equation to show. I'll try breaking it up:
For the field from the positive charges, I have [tex]\frac{2q}{4\pi\epsilon_0(r^2)}[/tex]
For the negative charges, [tex]\frac{-2qr}{4\pi\epsilon_0[(r^2+d^2)]^(\frac{3}{2})}[/tex]
Hopefully these will show
Meir's Suggestion
Thank you - I had thought of this, but don't see how to get the expression in the proper form. My terms are {1/r^2 - r/[(r^2+d^2)^(3/2)]}. I can get this into a form of
1-r^3/[(r^2+d^2)^(3/2)], but this is a form of 1-x, not 1/(1-x). Am I missing something obvious?
Rewrite [tex](r^2+d^2)^{3/2}[/tex] as [tex]r^3(1+(d/r)^2)^{3/2}[/tex]
Now you can take advantage of the approximation:
[tex]\frac{1}{(1 + x)^a} \approx 1 - ax[/tex]
(when x << 1)
