Electric field at specific point
The discussion revolves around determining the electric field at a specific point P due to a uniformly charged thin rod positioned along the x-axis. The rod has a total charge Q and extends from -a to a, with point P located at (2a, 0) in a vacuum.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the assumption of a uniform linear charge distribution along the rod and consider how to express the electric field contribution from an infinitesimal charge element. There are attempts to integrate the contributions of the electric field vectors, with some participants expressing uncertainty about their calculations and integration limits.
Participants are actively engaging with the problem, questioning assumptions about the setup and the mathematical expressions used. Some guidance has been offered regarding the correct integration limits and the need to express distances as functions of the variable x. There is a recognition of the parallel nature of the electric field contributions, and participants are working through the implications of their findings.
There are ongoing discussions about the appropriateness of using certain variables and expressions, with some participants noting potential mistakes in previous calculations. The conversation reflects a collaborative effort to clarify the problem and refine the approach without reaching a definitive solution.
cdummie
< Mentor Note -- thread moved to HH from the technical engineering forums, so no HH Template is shown >[/color]
Determine the electric field in point P with coordinates (2a,0), if there's thin rod charged with electric charge Q and it's laying on x coordinate with length from -a to a, and it it's placed in vacuum.
If it is a thin rod then you may assume a linear charge distribution in the segment [-a,a]. I assume this distribution is uniform. Try to express an infinitesimal portion of the Electric field created at point P (## d\vec E## ) by an infinitesimal charge (## dq ##) at arbitrary position x in [-a,a]. I'll leave you to think a bit more about it.
I think i know what you mean, i'll try to solve it by summing (integrating) contributions of all dE vectors, when i solve it i'll post it here.
I tried integrating it but every time i end up with this:
But i know it's not correct since result is zero so i probably made a mistake but i can't find where.
That is what I meant. Still, there are some issues in your work:
  1. Your second equation should have vectors to be coherent with what you are doing in the first one (just multiply by the unitary vector that has the direction of the line that goes from the charge to the point P). Luckily, all the contributions to the electric field are parallel, so the vector will be constant in the integral.
  2. Why use ##dl## when your rod is parallel to coordinate ##x##?
  3. Be aware that ##r## is the distance from the charge (##dQ##) to point ##P##. Can you express it as a function of ##x##?
You should not arrive to this integral if you do it right, but I must tell you that it is not zero: actually it is a divergent improper integral (note that ## r \rightarrow 0 \Rightarrow \frac{1}{r^2} \rightarrow \infty ## ).
Check http://en.wikipedia.org/wiki/Improper_integral
So, basically i can use dx instead of dl since rod is parallel to the x coordinate?
Exactly: a piece of ##l## is a piece of ##x##.
So, is this better:
Yes but your integration limits are incorrect. You should be integrating (summing) contributions to the electric field of charges within the rod, not outside (##[a,3a]## is outside).
Furthermore, you should have the distance from the charge ##dQ## to the point P (that is, ##r##) expressed as a function of ## x ## (note that it is not identical to ##x##). Just to make things clearer, include the unitary vector:
## \vec {dE} = \frac {Q' dx}{4 r^2 \pi \epsilon_0} \vec i ##
where ## \vec i ## is the unitary vector in the ##x ## direction (remember that the electric field is a vector).
I know it's a vector but it makes no difference while calculating it, i see, i should put integration limits [-a,a] since that is the part with the electric field. I'll finish it and post it. Thank you.
Correct, since all contributions are parallel. Anyway, it does no harm. ; )
It would be different if point P coordinates were for example (2a, 2a), then there would be two components of a vector dE, anyway i tried to express r as a function of x and i got r=2a-x and this is what i got:
Where r' represents unitary vector (i hope 'unitary' is the correct term) that defines direction of the vector E'. Hopefully, this is correct, if it isn't please point it out, anyway i think i understand this kind of problems better now, thank you :)
Seems ok to me. Just to complete the problem, try to express ## Q' ## in terms of given data (##a ## and ##Q##).
I think 'unitary' is a bad translation... It is actually 'unit' vector: I'm sorry.
cdummie said:
thank you:)
I'm glad to help :)
  • · Replies 68 ·
