Electric field between charging capacitor
The electric field (E-field) between a discharging capacitor can be described by the equation E(t) = σ(t)/ε, where σ is the surface charge density. As the capacitor discharges, the original E-field decreases, generating a magnetic field (B-field) that in turn creates a secondary E-field. This interaction is governed by Maxwell's equations, particularly the relationship between electric and magnetic fields, which indicates that the E-field is influenced by both charge density and time-varying magnetic fields. The analysis of the E-field in a discharging capacitor can be approximated using the RLC time constant model.
  • Understanding of Maxwell's equations
  • Familiarity with Gauss's law
  • Knowledge of electromagnetic theory, particularly the relationship between electric and magnetic fields
  • Basic concepts of capacitors and their discharge behavior
  • Study the derivation and implications of Gauss's law in dynamic systems
  • Learn about the RLC circuit model and its application to capacitor discharge
  • Explore the effects of edge effects in electric fields between capacitors
  • Investigate the relationship between electric fields and magnetic fields through Faraday's law
Students and professionals in electrical engineering, physicists studying electromagnetism, and anyone interested in understanding the dynamics of electric fields in capacitors during discharge.
Aziza
I am confused about how to find the electric field between a discharging capacitor.
For example, let's say I have a fully charged capacitor, such that there is no current flow anywhere. Then there is an electric field between the capacitor which equals 2*sigma/epsilon_0.
But now the ciruit is opened, such that current begins flowing to discharge the capacitor. The the original E-field is decreasing (but still present), causing a B field to be generated, which also causes another E field to be generated. Is the E field then the sum of these two E-fields??
This is a good question. First I would like to point out one interesting thing you seem to be missing:
Now that you are adding a second E field that was generated by the changes of the first, wouldn't that second E also change, thus generating a second B field to be generated, causing yet a third E field?Anyway, one way to analyze this problem might be to imagine an idealized circuit where an infinite parallel-plate capacitor discharges exponentially according to its RLC time constant. See here: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/capdis.html. If you use that sort of arithmetic to calculate the electric field in the capacitor, you will get a good approximation in most realistic situations, and the magnetic effects you're talking about probably represent small corrections.
I believe the magnetic effects only really arise in the "edge effects" that you get rid of by making the two plates of your parallel plate capacitor have infinite extent in space. I think you can see this through staring at the Maxwell equation:
\nabla \times \mathbf{B} = \mu_0\left(\mathbf{J} + \varepsilon_0 \frac{\partial \mathbf{E}} {\partial t} \right)
J will be zero in the region between the plates of the capacitor so, \nabla \times \mathbf{B} = \mu_0\ \varepsilon_0 \frac{\partial \mathbf{E}} {\partial t}
Which means that the curl is a constant inside the capacitor (since we're assuming the region between the plates of the capacitor has constant E and constant ∂E/∂t).
If that were so then the magnetic field would cancel everwhere except near the edges. One way to think about this is if you think of the curl as the circulation around a point, then, for example, the circulation at a distance r to the left of point x would cancel the circulation around the point located 2r to the left of point x.
thanks for the response!
Also, I just saw a Griffiths problem where he treats the E-field between charging capacitor by just saying that E(t)=σ(t)/ε, where σ is the surface charge and is increasing...so then this equation is not completely correct...but since the B field for given changing E field is small, I guess it makes sense that the correction is small
It is just one electric field with 2 components :
1st component generated by the time varying charge distribution (in the plates of the capacitor) and
2nd component generated by the time varying magnetic field.
The time varying magnetic field has also 2 components:
1st component generated by the time varying current
2nd component generated by the time varying electric field
In electromagnetism we just have 4 basic "entities": Charges, Currents(=moving charges), Electric Field, Magnetic Field. It is just that these 4 entities interact with each other (for example an electric field interacts with charges and set em in motion which creates a current which creates a magnetic field which will alter the electric field which will alter the flow of charges and so on) that makes it kind of confusing when we try to think in a linear way of cause and effect. In short the fields affect the currents and charges distributions which in turn affect the fields. Maxwell's 4 equations give us with full mathematical accuracy how these 4 entities interact with each other.
The E field (which should be sigma/epsilon_0) is given by Gauss's law, which holds even for a discharging capacitor. The B field due to the current cannot change Gauss's law.
Gauss's law give us the delusion that the E-field depends only on the charge density which is true only for the electrostatic case.
Faraday's law also give us the delusion that the E-field depends only on time varying magnetic fields but that's true only if there arent any charges
What happens is that by knowing only the divergence or only the curl of a vector field u cannot uniquely determine the field. Only if u know both div and curl u can determine it.
Gauss's law shows the E-field depends only on the charge density, which is true for all cases.
No, in the general case you need the full Maxwell equations to determine the electromagnetic field. The charge density only determines \vec{\nabla} \cdot \vec{E} but not \vec{\nabla} \times \vec{E}!
I think that one way of looking at the modification of the E field whilst the Capacitor charge is changing could be to think in terms of a 'back emf' due to the inductance of the space between the plates.
  • · Replies 32 ·
  • · Replies 16 ·
