Electric field generated by a charged wire
10 replies · 4K views
Renaldo
A charge per unit length +λ is uniformly distributed along the positive y-axis from y = 0 to y = +a. A charge per unit length −λ is uniformly distributed along the negative y-axis from y = 0 to y = −a. Write an expression for the electric field at a point on the x-axis a distance x from the origin. (Use the following as necessary: k, λ, x, and a.)
E = k|q|/r2
I derived this equation by treating the ends of the wire as point charges.
Ey = 2kqa/(y2+x2)3/2
I quickly determined that the field vectors x and k would be 0.
For the y vector:
dEy = 2ak(dq)/(y2+x2)3/2
dq/dy = Q/2a
∫dEy = (4akQ/2a)∫dy/(y2+x2)3/2
= 2kQy/[x2(y2+x2)1/2]
2kλy/[x2(y2+x2)1/2]
The limits of integration are from 0 to a.
I am pretty sure this is not correct, and have been working at it for a while, so I would appreciate some help.
On the RHS, part of the expression is valid for any y in the range, but part of it is only valid at the endpoints. You later treat it as though it's valid over all y.
I think I understand what you are talking about. Here is my revised process.
Ey = kqy/[(x2+y2)3/2]
dq = λdy
dEy = kλydy/[(x2+y2)3/2]
The limits of integration are from -a to a. I choose to integrate from 0 to a and multiply the result by two.
2∫dEy = 2kλ∫ydy/[(x2+y2)3/2]
= -2kλ/[(x2+y2)1/2]
=-2kλ/[(x2+a2)1/2]
= -2kλ/[(x2+y2)1/2]
Better. But it's a definite integral. y should have turned into a.
=-2kλ/[(x2+a2)1/2]
How much better? Am I on the right track or am I already there?
Actually, I just input that answer to webassign and it didn't accept it. I am kind of frustrated. lol
Renaldo said:
=-2kλ/[(x2+a2)1/2]
... and a definite integral has two bounds.
ok. New answer for limits of integration 0 to a:
-2kλ/[(a2+x2)1/2]+2kλ/x
Here is an attachment showing all of my work.
That's what I get.
haruspex said:
That's what I get.
Yes, this worked. Thanks for your help.
