Electric Field in a cavity of a dielectric medium
The discussion centers on calculating the electric field strength at the center of a spherical cavity within a dielectric medium, specifically addressing the polarization charge represented as -σe cosθ. The field strength at the center is established as σe / (3σe) along the Oz axis. Additionally, the relationship for the polarization charge σe is derived as σe = 3E0ε0r - 1) / (2εr + 1), correcting a previous error in the equation. The discussion also emphasizes the use of Gauss' law and spherical harmonic expansions to analyze the electric field and potential inside and outside the cavity.
  • Understanding of Gauss' Law in electrostatics
  • Familiarity with dielectric materials and their properties
  • Knowledge of spherical harmonics and their applications in electrostatics
  • Concept of electric field strength and potential in dielectric media
  • Study the application of Gauss' Law in complex geometries
  • Explore the derivation and implications of spherical harmonic expansions
  • Research the behavior of electric fields in non-uniform dielectric materials
  • Learn about the relationship between polarization charge and electric field strength in dielectrics
Students of electromagnetism, physicists working with dielectric materials, and engineers involved in electrostatic applications will benefit from this discussion.
XCBRA
The polarization charge in the surface of a spherical cavity is [itex]-\sigma_e \cos\theta ,[/itex]at a point whose radius from the centre makes and angle [itex]\theta[/itex] with a give axis Oz. Prove that the field strength at the centre is [itex]\frac{ \sigma_e}{3 \sigma_e}[/itex] parallel to Oz.
If the cavity is in a uniform dielectric subject to a field strength [itex]E_0[/itex] parallel to the direction [itex]\theta = 0[/itex], show that
[tex]\sigma_e = 2 E_0 \epsilon_0 \frac{(\epsilon_r - 1)}{(1+\epsilon_r)}[/tex],
where [itex]\epsilon_r[/itex] is the relative permittivity of the dielectric.
First to find the field stength i have used Gauss' law:
[tex]\epsilon_0\int E.ds = \int \sigma da[/tex]
[tex]4\pi R^2 \epsilon_0 E = \int \int \sigma R^2 d\theta d\phi[/tex]
Then for the second part,
I have let [itex]V_1[/itex] for the potential inside the cavity and [itex]V_2[/itex] for the potential outside the cavity.
I assume that:
[tex]V_1 = B_1 r\cos\theta + \frac{B_2 \cos\theta}{r^2}[/tex]
[tex]V_2 = -E_0 r\cos\theta + \frac{A_2 \cos\theta}{r^2}[/tex]
then since [itex]V_2 \neq \infty, B_2 = 0[/itex].
Then since [itex]V_1 = V_2 at r=R[/itex]
[tex](B_1 + E_0) R^3 = A_2[/tex]
then find the radial electric field components:
[tex]E^r_1 = - \frac{\partial V_1}{\partial r} = -B_1 \cos\theta[/tex]
[tex]E^r_2 = - \frac{\partial V_1}{\partial r} = E_0\cos\theta+\frac{A_2 \cos\theta}{r^3}[/tex]
then taking the boundary condition
[tex]D^r_1= D^r_2<br /> <br /> \epsilon_0 \epsilon_r E^r_2 = \epsilon_0 E^r_1[/tex]
to give
[tex]B_1 = - \frac{3 \epsilon_r E_0}{2 \epsilon_r + 1}[/tex]
therefore inside the cavity:
[tex]P = (\epsilon_r - 1) \epsilon_0 E_1[/tex]
[tex]P.n = P \cos\theta = \sigma_e cos\theta[/tex]
[tex]P = \sigma_e = \frac{3(\epsilon_r-1) \epsilon_0 \epsilon_r E_0}{(2\epsilon_r +1)}[/tex]
I am not sure why i have the extra [itex]\epsilon_r[/itex] in the numerator, and I am not sure if there is a simpler method to do this?
Thank you for any help.
Did you not just asked the same question here: https://www.physicsforums.com/showthread.php?t=516394 ?
Write down the spherical harmonic expansion on either side of the boundary and match the appropriate boundary condition. The potential outside is particularly simple. Because at large distance from the cavity, it must reduces to [itex]\vec{E} = \frac{E_0}{\epsilon_r} \hat{z}[/itex], which corresponds to potential: [itex]\phi = - \frac{E_0}{\epsilon_r} z = - \frac{E_0}{\epsilon_r} r \cos\theta[/itex].
The question I had asked earlier was indeed the first part of the question, but I am now having trouble with he second part and felt necesary to include the first part answer and soltuion to give the context to the second part.
I just realsied that there is typo in
and it should indeed be:
[tex]\sigma_e = 3 E_0 \epsilon_0 \frac{\epsilon_r -1}{2\epsilon_r +1}[/tex]
with regards to the expansion. Wouldnt the field outside the cavity need to have an extra term other thant just the term at infinity as the cavity will distort the field around it?
With the expansion i did above,
I get for inside the sphere [itex]V_1 = - (\frac {3\epsilon_r}{1+2\epsilon_r}) E_0 r \cos\theta[/itex]
then for outside: [itex]V_2 = - (1-\frac {R^3(\epsilon_r - 1)}{r^3(1+2\epsilon_r)}) E_0 r \cos\theta[/itex],
however i am not entirly sure i understand how to then go about finding the surface charge density of the cavity?
Thnak you for you time.
