Electric Field of a Cylinder (Hollow/Solid) at the face
The discussion revolves around calculating the electric field at the origin due to two types of cylinders: a hollow cylinder with charge density σ and a solid cylinder with charge density ρ. The participants explore the integration of electric field equations related to charged rings and disks to find the electric field at a specific point.
  • Participants discuss integrating the electric field of a charged ring and a charged disk to find the electric field at the origin. There are questions about the correct setup of integrals and the representation of charge density in terms of dq, σ, and ρ. Some participants express confusion over the dimensions of their results and the interchangeability of σ and ρ.
There is ongoing exploration of the mathematical setup for both parts of the problem. Some participants have provided clarifications regarding the differences between charge densities and the correct expressions for area. While some have reached conclusions about their calculations, others are still grappling with the integration process and the implications of their findings.
Participants note issues with undefined solutions when integrating and emphasize the importance of correctly expressing charge density in terms of the respective variables. There is also a mention of needing to evaluate limits as z approaches infinity for the integration results.
adenine7
Part a.
A cylinder (with no face) is centered symmetrically around the z axis, going from the origin to infinity. It has charge density σ and radius R. Find the electric field at the origin.
Part b.
Same problem, except this time instead of a hollow cylinder with no face we have a solid cylinder. It also now has charge density ρ. Find the electric field at the origin.
Ering = kQz/(z2+ R2)3/2
σ =dq/2πRdz
Edisk = σ/o * (1 - z/(z2+R2)1/2)
ρ =dq/πR2dz
3. The Attempt at a Solution
I understand that to complete part a I must integrate the electric field of a charged ring (a distance z from its center) from z = 0 to z = ∞. I understand that to complete part b I must integrate the electric field of a charged disk (a distance z from its center) from z = 0 to z = ∞. Here is my solution to part a (I'm not sure if it's correct):
EHollow Cylinder = ∫0 kQz/(z2+ R2)3/2 dz = kσ2π/R
I don't know how to set up the integral for part b. When I integrate the equation for Edisk, with a dz tacked onto the end (not so sure about this), I get undefined. Is this a part of the problem, or is my math incorrect?
Anyone have any ideas?
If you check the dimensions of your answer, you can see that it has the wrong dimensions for electric field.
The integral should represent a "sum" of fields of infinitesimally thin rings. The charge in one of the rings will be infinitesimal and should be represented by dq rather than Q. You can express dq in terms of the the charge density σ and dz. (This is how dz gets into the integral.)
Thanks for the reply!
I think I made a mistake typing that in; the equation I integrated (which I did not correctly transcribe, sorry for the confusion) is with dQ = σ2πRdz (that's why my final answer has σ2π in it).
Assuming this is the correct answer, here's where I get stuck with part b. Rather than being able to manipulate Q into an expression of σ and area, the equation for the electric field of a disk already has σ (which I assume can just be replaced with ρ). I don't see anything I can manipulate but the ρ to get a dz into the equation, but when I do that I get a dq and a dz.
Yes, dQ = σ2πRdz. But, your answer to part (a) is not correct. You can see that your result has the wrong dimensions for an electric field. I think you are probably just making a minor error in not keeping track of the factors of R.
You cannot replace σ with ρ. They do not have the same meaning or the same dimensions. If dQ represents the total charge in one of the disks of thickness dz, try expressing dQ in terms of ρ, R, and dz. Then, get an expression for σ in terms of ρ and dz by noting that σ = dQ/(area of disk).
Part a.
If I integrate kσ2πRz/(z2+ R2)3/2 dz from 0 to ∞ I get kσ2π, which checks out with dimensions. I believe I was forgetting to integrate with the extra z in the numerator (which does not get replaced by dz).
Part b.
Thank you for explaining the difference between ρ and σ! I thought they were interchangeable.
dQ = ρπR2dz
σ = dQ / 2πR = ρπR2dz / 2πR = ρRdz / 2
However, integrating with this substitution from 0 to ∞ still gets me an undefined solution.
0 (ρR / 4εo) * (1 - z / (z2+R2)1/2) dz = [(ρzr / 4εo) - (ρr (z2 + r2)1/2 / 4εo)]0
adenine7 said:
Part a.
OK. That looks good. Of course, you could express your answer in terms of ε0 instead of k.
Part b.
dQ = ρπR2dz
Is 2πR the correct expression for the area of the disk?
To evaluate "at infinity" you need to take the limit of the expression as z → ∞. You should find that the limit is finite.
Expressing my electric field for a hollow cylinder in terms of εo, I get σ / 2εo. So, this is the same as the electric field for an infinite sheet of charge at distance z away?
For part b., I changed the expression for σ (fixed the area of a disk) and got σ = ρdz. I did what you said and expressed the integral evaluation as E = limb → ∞- [E(b) - E(0)]. I get E = ρR / 2εo. This checks for the dimensions of E, I believe (though clearly I'm prone to simple mistakes).
Yes. That's an interesting coincidence!
That all looks correct to me. Good work.
Thank you so much for your help! You're a great teacher.
  • · Replies 36 ·
