Electric field, potential, and Charge Displacement
The discussion clarifies the behavior of electrons in a uniform electric field (E field). When an electron, a negative charge, moves opposite to the direction of the E field, it indeed moves towards increasing potential energy per unit positive charge. This is because the electric field points towards decreasing potential, while the electron's movement aligns with the increase in potential energy for negative charges. The key takeaway is that the movement of negative charges in an electric field is counterintuitive but consistent with the definitions of electric potential and potential energy.
  • Understanding of electric fields and their properties
  • Knowledge of electric potential and potential energy concepts
  • Familiarity with the behavior of charges in electric fields
  • Basic principles of electrostatics
  • Study the relationship between electric fields and electric potential
  • Learn about the concept of potential energy in electrostatics
  • Explore the behavior of different charge types in electric fields
  • Investigate the mathematical representation of electric fields and potentials
Students of physics, educators teaching electrostatics, and anyone seeking to understand the dynamics of charges in electric fields.
teroenza
I am confused about an electron ( or any negative charge) moving in a uniform E field. If the electron moves in the opposite direction of the electric field, and the E field points in the direction of greatest decrease in potential, then it seems like the electron is moving in the direction of increasing potential.
I know this is wrong, and I must be missing a negative sign somewhere. Can someone please correct me?
Thank you
No correction needed. This is right. Potential at a point in an electric field is defined as the potential energy per unit (positive) charge at that point compared to a unit charge at infinity (E = 0).
So an electron always moves in the direction of increasing potential energy per unit positive charge (ie. increasing potential), which is the same direction of decreasing potential energy per unit negative charge.
AM
