Electric Field Problem-Balancing Forces
The discussion centers on solving a physics problem involving a 0.020g plastic bead suspended by a thread and another charged bead positioned below it. The key equations utilized are the gravitational force equation (w=mg) and Coulomb's law (F=[K(q1)(q2)]/r^2). Participants emphasized the importance of separating the forces into x and y components, specifically using Tsin45 for the electric force and Tcos45 for the gravitational force. The final calculation yielded a charge q of 6.20*10^-9 C, confirming the approach taken was correct.
  • Understanding of Coulomb's law and electric forces
  • Knowledge of gravitational force and weight calculations
  • Ability to resolve forces into components using trigonometric functions
  • Familiarity with basic algebra for solving simultaneous equations
  • Study the derivation and application of Coulomb's law in electric force problems
  • Learn how to resolve forces into components using sine and cosine functions
  • Practice solving simultaneous equations in physics contexts
  • Explore the implications of electric forces in equilibrium scenarios
Students studying physics, particularly those focusing on electrostatics and force balance problems, as well as educators looking for examples of force resolution in practical applications.
tyreal
A 0.020g plastic bead hangs from a lightweight thread. Another bead is fixed in position beneath the point where the thread is tied. If both beads have charge q, the moveable bead swings out to the position shown (attachment). What is q?
F=[K(q1)(q2)]/r^2
w=mg
I am new to physics forums so please excuse my equations formatting! I know this is a force balancing problem. I think that tension force of string equals weight force of bead. There is a repulsive electrical force between the two beads, which I think equals the tension/gravitational force that is holding the bead in place.
T=mg=0.000196N
My question is, should I set this equal to the expression of [K(q1)(q2)]/r^2 and solve for q? I know that is the last step since I am trying to find q. BUT, my professor said we had to use sin45 or cos45 in some way so as to separate the x and y components of the force. I don't see where to incorporate that. I am missing some sort of middle step here, any input would be appreciated!
F=[K(q1)(q2)]/r^2
w=mg
T=mg=0.000196N
Hi tyreal! Welcome to PF.
Remember when we write force balancing equations we want to balance the forces in both x and y directions separately.
Hint: The force of gravity only has a y component. Thus, the force of gravity must be balanced out by the y component of the tension force. Similarly, in this problem, the electric force has only an x-component. Thus, the electric force is balanced by the x component of the tension.
Can you write two force balancing equations expressing the above?
Okay, that helped a lot. Here is what I got when I separated the two:
Fx(electric)=Tsin45=[K(q1)(q2)]/r^2
Fy(gravity)=Tcos45=mg
Can I assume T=mg for both the x and y cases? Then I can ignore the Y component since the question is only asking about forces that are on the X axis.
Solving mg*sin45=[K(q1)(q2)]/r^2, using 9*10^9 for K, 0.05m for r, 0.00002kg for m and 9.8 for g, I get q=6.20*10^-9 C, which seems appropriate.
But you have just shown that Tcos45=mg.
haruspex is correct. If the rope was hanging straight down, T=mg, but that is not the case in this problem because of the electric repulsion.
Use the two equations you have to solve for q.
Very good input here! Thank you for pointing that out haruspex. If I cannot assume T=mg for the horizontal forces (supported by commonsense reasoning!), what would I use for T? And what would I be left with to set equal to [K(q1)(q2)]/r^2? G01, I am not sure which two equations you are referring to.
These two:
Tcos45=mg
You have two equations and two unknowns, T and q. You should be solve the equations simultaneously and solve for both T and q.
  • · Replies 16 ·
