Electric field strength at the midpoint between the two charges.
The electric field strength at the midpoint between a +7.3 nC point charge and a -2.4 nC point charge, which are 3.5 cm apart, is calculated using the formula E = k(q/r²). The distance from each charge to the midpoint is 1.75 cm (0.0175 m). The electric field contributions from both charges are E1 = 214,531 N/C and E2 = -70,530.6 N/C, resulting in a total electric field strength of 144,000 N/C. However, the correct answer is not among the provided multiple-choice options, indicating a potential misunderstanding of the directionality of the electric fields.
  • Understanding of Coulomb's Law and electric field calculations
  • Familiarity with the concept of electric field directionality
  • Knowledge of point charge properties and their effects on electric fields
  • Basic proficiency in unit conversions (cm to m)
  • Review the principles of superposition in electric fields
  • Study the effects of charge polarity on electric field direction
  • Learn about the implications of electric field strength in practical applications
  • Explore the concept of electric field lines and their representation
Students studying electromagnetism, physics educators, and anyone preparing for exams involving electric field calculations and charge interactions.
momopeaches
A + 7.3 nC point charge and a - 2.4 nC point charge are 3.5 cm apart. What is the electric field strength at the midpoint between the two charges?
E = 9*10^9(q/r^2)
q = charge
r = distance from point charge
Since the question asks for the field strength between the two charges, r would be 1.75 cm or .0175 m.
Therefore
E = E1+E2
E1=9*10^9(7.3*10^-9/.0175^2)
E1=214531
E2=9*10^9(-2.4*10^-9/.0175^2)
E2=-70530.6
E=144000 N/C
Except it says I'm wrong. Its multiple choice, and the other choices given are
1900 N/C
5700 N/C
2.8×10^5 N/C
If you keep a positive test charge at the mid point, positive charge will repel it and negative charge will attract it. So E1 and E2 are in the same direction. Hence
E = E1+E2 = 214531 + 70530.6 = ...?
So, to make this work, would my E2 equation have to be E=9*10^9(q/-r^2)? I don't know what you mean when you say E1 and E2 are in the same direction.
The magnitude of E2 = k*q2/r2 and the direction is towards -2.4 nC.
The magnitude of E1 = k*q1/r2 and the direction is towards -2.4 nC.
where r = d/2.
