Electric field using dielectric constant
The discussion revolves around calculating the electric field due to a point charge in a medium with a dielectric constant, specifically underwater. The original poster presents a problem involving a charge of 6.0 x 10-9 C located 0.025 m away, seeking to understand how to incorporate the dielectric constant of water into the electric field calculation.
  • Participants discuss the application of the equation for electric field strength, questioning how the dielectric constant affects the calculations. Some suggest using a modified formula that includes the dielectric constant, while others inquire about the relevance of Gauss's law in this context.
There is an ongoing exploration of how to properly apply the dielectric constant in the electric field equation. Some participants have provided guidance on using specific equations, while others are questioning the assumptions regarding the surrounding medium and the implications of using Gauss's law.
Participants note the potential confusion arising from the relationship between dielectric constants and electric fields, particularly when the surrounding environment is not specified. There is also mention of the need to distinguish between free charge and bound charge in the context of dielectrics.
Issy
What is the magnitude of the electric field due to a 6.0 x 10-9 C charge at a point located 0.025m from the charge? The charge and the point in question are located underwater (κ(water) = 80).
I know that E = magnitude of electric field = kq/r2, where k = Coulomb's constant of 9 x 109, and I also know that κ = kappa = dielectric constant aka relative permittivity of a dielectric material, which we use in the equation C = capacitance = κεoA/d.
However, I can't workout how to use κ to find electric field strength, because I don't see how a capacitor is involved in this situation? And with the three variables I have been given (the size and electric polarity of charge, the distance, and the dielectric constant of water), I also don't know of any formulas I can use that don't require any other variables.
The practise test I'm working on is multichoice, and the answers state that the final answer is equal to 1.1 x 103 N/C, but I'm not sure how to work backwards from that either. Any help would be greatly appreciated! We have a test later this week, and I'm sure Murphy's Law will make sure that unless I get my head around it, a question like this will no doubt be in the exam, so any and all advice will be welcomed!
use this equation E=Kq/kr^2,where
K= 9 * 10^9
k=dielectric constant
q=charge
r=distance in question
Edit: Answer is 1.08 * 10^3 N/C
Equation reference: H C Verma Concepts Of Physics
Do you need any proof of this equation?
K= 9 * 10^9
q=charge
Thank you very much! So, is it fair to say that dielectric constant (ie Kappa) is actually always used in the E=kq/r2 equation when the surrounding environment is not specified? Which would mean it's assumed that it's just air, which has a dielectric constant of 1, so doesn't actually affect the equation?
...I guess what I'm asking, in a roundabout way, is should I use that equation for any question where the surrounding environment of the charge is not air?
Thank you again for your help, I had no idea how to approach it, you've saved me a lot of confusion!
Yes.. You are right! Thank you! you are welcome!
There is one thing that you should know... Once you use kappa in the equation.. you should never use the bound charge appearing due to polarization of the dielectric.
only free charge should be used..
Use a gaussian surface around your charge, and Gauss's law.
Now you can handle any combination of charge and observation point being surrounded by various dielectric material.
I'm going to bookmark this thread, because while I currently have no idea about Gauss' Law, no doubt I'll find out about it next semester, or soon enough. Thank you for your advice! Sometimes it seems like every time I learn a new physics concept, I become aware of half a dozen others that I also need to learn - but it makes my degree more entertaining if I think of it as fighting a Hydra! Thank you again
The constant K we use in finding the electric field is= $$\frac {1}{4\pi \epsilon_0}$$
So , when you are talking about an dielectric just replace the ##\epsilon_0## part with ##k\epsilon_0## where k is the dielectric constant , just the way you do for the capacitors. Thats why you get that k in the denomimator of the formula.
Har! Are you going for a physics major or something like "physical sciences" where calculus-level physics is not covered? My school had that option & most others do too I'm sure. So you may or may not run into Dr. Gauss.
  • · Replies 40 ·
10K
