Electric force (varying) on q from Q (conceptual question)
The discussion revolves around calculating the electric force acting on a charge q from a fixed charge Q, with q positioned on the y-axis. The user inquires whether integrating the electric force formula can determine the force required to move q a distance "a" along the y-axis. It is clarified that while the force varies according to Coulomb's law, integrating with respect to distance will yield the work done by the force, not the force itself. The importance of understanding that the area under the force versus distance graph represents work done is emphasized. This highlights a common misconception in applying integration to variable forces in electrostatics.
Antonius
Let's say Q is a charge at fixed position on the x - axis. There is another identical charge q on the y - axis. There is an electric force acting on q from Q (and it's not constant.) My question is can I find force acting upon q from Q to move q to a certain distance "a" , along y - axis (distance "a" from it's original position.)
Now that I have stated the conditions, my question - Can I integrate the Electric Force = q Q / ( 4 π ε ) ∫ 1 / r^2 to find the force that acts on q due Q which causes q to move a distance "a"
If you have a link to a source that explains this whole idea of varying electric force please let me know, that would be a massive help.
Thank you :)
You already know the force. It's a variable force whsose magnitude at any point is given by coulombs law. If you integrate it with respect to dr, as you have suggested, you'll get work done by the force, not force.
Likes Antonius
Thanks a lot! Yesterday, I completely forgot that the area under F x d graph is a work done by the force...
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
