Electric generator coil design
This discussion focuses on the design of electric generator coils, specifically addressing issues related to voltage output and coil specifications. The user, DC, initially calculated a theoretical output of 80 volts using Faraday's induction formula, but experienced lower actual voltage. Key factors influencing performance include the number of turns (N), the area of the coil (A), and the magnetic flux density (B). Suggestions for improving design include reducing the air gap between magnets and coils and considering various motor types for different generator sizes.
  • Understanding of Faraday's induction formula (V = N A (2 pi RPM/60) B)
  • Knowledge of magnetic flux density (B) and its impact on voltage generation
  • Familiarity with different types of motors (DC brushless, AC induction, etc.)
  • Basic principles of electromagnetic induction and coil design
  • Research the effects of wire gauge on induction and voltage output
  • Explore designs for DC brushless motors in generator applications
  • Investigate the use of AC induction motors for standalone power generation
  • Learn about optimizing magnetic field strength in generator designs
Engineers, hobbyists, and DIY enthusiasts interested in electric generator design, particularly those working on wind or alternative energy projects.
DeepCut
Hi,
i am developing a home-made generator but i am having some trouble with coil design.
Going on Faraday's induction formula :
a 50 turn coil with a radius of 20mm going at 20,000 RPM should give me 80 volts or so, in practice i am getting much less than this.
Does wire gauge have no bearing on induction, i would have thought that a finer wire would give me a higher voltage ?
Any help greatly appreciated,
DC.
(I'm a new member) Can someone help me with a windmill generator design? I'm working on a 9.9 kw machine (45 kw max) prototype and need some assistance in induction generator design, both ac and dc coils.
You know how many windings on you're pole piece, and have a fair idea what your rotational velocity is, that leaves your flux density, B, as you most likely culprit. To get sufficient field strength, you need to keep your flux flowing either through the magnets or iron. An air gap is necessary for mechanical reasons, but you don't want it to be large.
For a fun, demonstrator generator, it's hard to be a step motor with a crank. They can put out a few volts at hand cranking speeds, which makes them great for science fair demonstrations.
For slightly larger designs, DC motors are sometimes good. I've hear that the ones used in tread mills can be used in small wind generators.
For something slightly larger, a DC brush-less motor is great. More and more, they use these in appliances - especially air conditioner air handlers. They also use small ones for RC models.
If you wish to get larger, the AC induction motor is often the way to go. When driven beyond it's synchronous speed, it behaves as a current source. However, it's not a good option for stand alone power and should have some support components for start up and to ensure that it's current is mostly in phase with it's voltage.
I've also heard of using car alternators, though I understand that this can be a bit difficult due to the required excitation current, output voltage, etc. Anyway, supposedly a Kid in Africa set up a number of DC systems using this technology.
So many people are building these things, you might as well learn from their experiences. If you Google "diy wind power coils", there are many sources of plans, videos, etc.
wow - you're talking 60 horsepower here..
hard part is to find something suitable for low speed.
i'd see if local metal scrap yard has electric forklift with salvageable motor.
Thanks for the answers, sorry i never replied before. Massive life changes took me away for over a year !
DC.
Can you please explain more about this formula? what are N, A and how to choose B?
N is the number of turns in the coil, A is the area of the magnet face and B is the magnet strength in Tesla.
I think I've got that right.
I am thinking about the problem and i think that rotating the magnetic field at speed 20000 rpm is very high, it will not let the coil to sense the change in flux to generate the required voltage.
No, higher RPM results in more voltage. The problem is solved now, just move the magnet nearer, because the B field drops off in strength in a big way as you move further from the coils.
Thank you,
DC.
  • · Replies 51 ·
  • · Replies 24 ·
  • · Replies 28 ·
  • · Replies 28 ·
17K
  • · Replies 74 ·
9K
