Electric potential and conducting wire
7 replies · 2K views · last reply
Hardik Batra
There are two sphere of radius a and b and they are connected by conducting wire. Then why the electric potential becomes same of both the sphere?
Let's say there was a small potential difference initially between the spheres when you connected them with the conducting wire. What happens next?
I don't know what happens next that was I am asking to you. Why potential becomes same?
And I'm asking you -- when you have a potential difference across a conducting wire's ends, what happens? Approximate the wire as a 1 Ohm resistor for simplicity. What is Ohm's Law?
I think electron will move from higher potential to lower potential.
Good! What does that electron movement do to the overall potential difference between the two spheres?
Electron moving from higher potential it will release the energy and higher potential decrease?
Correct, the potential decreases. Just think of the 2 spheres as the 2 plates of a parallel-plate capacitor. When you have a charged-up capacitor, and you connect a resistor across the terminals of the capacitor, the capacitor discharges through the resistor until there is 0 Volts across the capacitor (so the plates are at the same potential).
Does that make sense?
