Electric potential at center of semicircle
The discussion focuses on calculating the electric potential at the center of a semicircle with a uniformly distributed charge Q along a thread of length L. The correct approach involves using the formula V = kQ/r, where r is expressed in terms of L. Participants clarify the relationship between charge density and differential charge, leading to the conclusion that dQ = (Q/L)dL. The final expression for electric potential is derived as V = kQπ/L, confirming the semicircle's geometry and charge distribution are correctly applied.
  • Understanding of electric potential and electric field concepts
  • Familiarity with calculus, particularly integration techniques
  • Knowledge of charge density and its relation to differential charge
  • Basic geometry of semicircles and their properties
  • Study the derivation of electric potential from electric field using calculus
  • Learn about charge density and its applications in electrostatics
  • Explore the relationship between arc length and radius in circular geometries
  • Investigate the use of different variables in integration to avoid confusion
Students and educators in physics, particularly those focusing on electrostatics, as well as anyone involved in solving problems related to electric potential and charge distributions.
toothpaste666
A total charge Q is uniformly distributed on a thread of length L. This thread forms a semicircle. what is the potential at the center? (assume V=0 at large distances)
V = -∫Edl
E = kQ/r^2
V = - ∫Edr = -E∫dr = -Er = - kQr/r^2 = -kQ/r
is this correct? I am not sure if the sign should be negative
E is a vector and it is not constant. Finding the electric field is more complicated, it is sufficient to calculate the potential here but that has a different formula.
Also, using r both for radius and for the length along the circle is confusing and leads to wrong results.
hmmm so would it be correct to say
V = ∫dV = k∫dQ/r = kQ/r because Q is constant?
The result is right but you'll have to justify the steps you used.
Does this mean i have to plug something in for dQ?
The length should appear somewhere.
Oh, and I guess the final result should be expressed in terms of L instead of r as well I guess.
I think i can use arc length formula L = theta r to relate r and L. I am not sure how I can plug that into the equation for V. I think this doesn't seem like it should be a tough problem but I must be missing something obvious =[
This is not a tough problem. Yes you can use the arc length formula.
If a charge Q is uniformly distributed over a length L, what is the charge per length?
I think it would simply be Q/L so dQ in terms of the charge density would be dQ = λdL = (Q/L)dL
V = k∫dQ/r = k∫(Q/L)dL/r = kQL/Lr = kQ/r ??
Looks fine. Now you just have to express r in terms of L.
The semicircle has a length of L.
so since L = theta r then r = L/theta so the final step would be
kQ/r = kQtheta/L
but since they don't give me theta can I get away with doing this?
assuming a semicircle is a half circle (forgive me if this is incorrect I am not 100 percent sure) then L would equal the perimeter or L = (pi/2)r^2
so r = sqrt(2L/pi) so it would be kQ/(sqrt(2L/pi))
Yes, semicircle just means half-circle
toothpaste666 said:
L = (pi/2)r^2
I think you're mixing up the area and circumference formulas. On the left side you have units of length but on the right side you have units of length squared.
oops sorry L = 2(pi/2)r = pi r
so r = L/pi
so kQ/r = kQpi/L
Right.
thanks guys
i feel like i did something wrong. if my integral was k∫(Q/L)dL/r then wouldn't it be
k∫(Q/L)dL/r = kQ/r∫dL/L(because Q and r are constant) = kQ/r (ln(L)) ??
or If i put everything in terms of L instead of r from the begining:
k∫((Q/L)dL)/(L/pi) = k∫piQdL/L^2 = kpiQ∫dL/L^2 = - kpiQ/L
so it would be negative?
If you use L like this, you have to integrate over a different variable, like L' (or x, or whatever). The L in Q/L does not change in the integral.
the L in r = L/pi changes? How would I have to set that up for it to be correct?
No it does not change!
That's why it is better to use a different integration variable along the length of the semicircle, like x.
  • · Replies 22 ·
  • · Replies 18 ·
