Electric Potential Between Multiple Points
The discussion revolves around calculating the electric potential difference between points 3 and 4 (V34) given the potential differences V12, V23, and V41. The key equation used is that the sum of potential differences around a closed loop equals zero, leading to the equation V12 + V23 + V41 + V34 = 0. Substituting the known values, V34 is determined to be -140V, indicating a negative potential difference. The participants emphasize the importance of understanding how to manipulate the equations to find the unknown potential difference. The conversation highlights the confusion surrounding the application of these principles in solving the problem.
Mitchtwitchita
There are four points. The electric potential difference between points 1 and 2 (V12) is 30V, the electric potential difference between points 2 and three (V23) is 50 V, and the electric potential difference between points 4 and 1 (V41) is 60 V. What is the electric potential difference between points 3 and 4 (V34)?
V = kq/r
I have no idea how to get this one started. Can somebody please help me if you can?
The only relevant equation here is potential difference between point A and B V_{AB}=V_A - V_B
How would I go about getting this problem started with that equation?
Write down all potential differences provided and asked in the problem in that form, and you will see the miracle.
I'm not seeing any miracle.
V1 - V2 = 30V
V2 - V3 = 50V
V4 - V1 = 60V
V3 - V4 = V34?
V12 = V1 - V2
V23 = V2 - V3
V41 = V4 - V1
V34 = V3 - V4
And: V12 + V23 + V41 + V34 = ?
I want to say the total is 150V and that V34 is 10, but I don't know why?
Where do you get that 150V?
Again:
V12 = V1 - V2
V23 = V2 - V3
V41 = V4 - V1
V34 = V3 - V4
If I add these four equations together, I will have V12 + V23 + V41 + V34 = ?
I really don't know, nor do I have a guess. We don't know what V34 is, so how would it be possible to know the answer?
If
A=B
C=D
then
A+C=B+D
Does that help?
So, V12 + V23 = V41 + V34?
30V + 50V = 60V + x
x = 20V?
No. It doesn't follow from what you have. I just gave you an example with two equations. What works with two also works for three and four and five and so on. Use that fact and try answering hikaru1221's question.
I'm really perplexed by this problem, and am not understanding the concepts you are giving me. Is there any other information that you can give me that may enable me to grasp this problem better?
If you have any number of equations, you can together everything on the left side and that will be equal to what you get when you add together everything on the left side.
Example
2 = 1+1
3 = 1+2
-2 = 2-4
4 = 2+2
Then
2+3+(-2)+4 = (1+1)+(1+2)+(2-4)+(2+2)
What works with numbers works with symbols that stand for numbers.
So, V12 + V23 + V41 + V34 = 140 V + x ?
Where did you get that? Show me exactly how just like I showed you in the previous example with numbers.
O.K. This problem has gotten me totally confused!
Would this be what I'm looking for?...
V12 = V1 - V2
V23 = V2 - V3
V41 = V4 - V1
V34 = V3 - V4
V12 + V23 + V41 + V34 = (V1 - V2) + (V2 - V3) + (V4 - V1) + (V3 - V4)?
Ok, if you connect two voltages by having each voltage share the same point as their junction, then you've found a new voltage between the two points in the extreme.
V_{ab} + V_{bc} = V_{ac}
shown here:
V_{ab} = V_a - V_b
V_{bc} = V_b - V_c
V_{ab} + V_{bc} = V_a - V_b + V_b - V_c = V_a - V_c = V_{ac}
also, notice this result:
V_{ab} = V_a - V_b
then
-V_{ab} = -(V_a - V_b) = V_b - V_a = V_{ba}
So you basically have to use these results to make a chain of voltages that are properly connected to find v34. These rules apply to any number of voltages, too:
V_{12} + V_{23} + V_{34} = V_{14}
That's what you are looking for. Now remove the parentheses from all the terms on the right side and add things together. What do you get on the right side?
Is this what I should be looking for?:
V12 = V1 - V2
V23 = V2 - V3
V41 = V4 - V1
V34 = V3 - V4
V12 + V23 + V41 + V34 = (V1 - V2) + (V2 - V3) + (V4 - V1) + (V3 - V4)??
Disregard the last post. If I remove the brackets, then all of them cancel and I'm left with 0.
So you know that
Can you find V34?
So, I have V12 + V41 = V1 - V2 + V4 - V1 = V42
V42 + V23 = V4 - V2 + V2 - V3 = V43
I don't know where to go from here...
Please explain how you got that from (*** On edit *** actually don't - it is irrelevant to the problem)
What do V12, V23, V41 and V34 stand for? Do you have any values for any of them?
I guess I'm not getting the rules. I was using what xcvxcvvc posted as a guide. I don't know where to plug the values in.
Plug the values in the equation
What do you get?
V34 = 140 v?
If the sum of four terms is zero and three of them are positive can the fourth term also be positive?
Sorry, -140V?
Much better. You're done with this.
  • · Replies 22 ·
