Electric Potential Difference homework help
The discussion revolves around the electric potential difference and the behavior of a test charge in the presence of two negatively charged rods. The original poster presents a scenario involving the movement of a test charge along a circular path and poses questions regarding the direction of electric force, work done by the electric field, and the electric potential difference.
  • Participants discuss the direction of electric force on the test charge at points X and Y, with some suggesting that the force direction may be negative due to the nature of the charges involved. There are varying interpretations of the work done by the electric field, with some asserting it is positive while others question this conclusion. The relationship between electric potential energy and kinetic energy is also debated, particularly regarding the speed of the test charge at point Y compared to its initial speed.
The discussion is ongoing, with participants exploring different interpretations of the forces and energies involved. Some have provided insights into the relationship between force, displacement, and work, while others are seeking clarification on their reasoning and assumptions. There is no explicit consensus, but various lines of reasoning are being examined.
Participants are working under the constraints of their current knowledge and understanding of electric forces and potential energy, with some expressing uncertainty about their conclusions and seeking further clarification.
cy19861126
Two charged rods, each with net charge -Qo, are held in place as shown in the diagram below
a) A small test charge -qo travels from point X toi point Y along the circular arc shown.
i. Draw an arrow at each point (X and Y) to show the direction of the electric force on the test charge at that point.
ii. Is the work done on the charge by the electric field positive, negative, or zero?
iii. Is the electric potential difference positive negative or zero?
b) The test charge is launched from point X with initial speed vo and is observed to pass through point Y. Is the speed of the test charge at point Y greater than, less than or equal to vo?
V = (delta PE)/q
W = Fd
a) i. The electric force at X is pointing at southwest direction and force at Y is pointing at North direction
ii. Positive. W = Fd. For the rod on the left, the force exerted on the object is 0, so the rod has no effect on the test charge. However, the rod on the right exerts a positive force on the test charge. This is because the force direction from the rod and the displacement are pointing at the same direction
iii. Negative. The difference in electric energy is positive because point X is closer to the negative rods than point Y. And since V = (delta PE)/q. Delta PE is positive and q is negative, so the electric potential difference must come out to be negative.
b) Greater than. -PE = KE. If electric potential energy is negative, then KE must be positive. Thus, greater velocity
Hi.Is this a show-case?
Show case? What are you talking about. I put on the questions I have problems on and then I put the answers I thought to be correct. Although I don't expect any of them to be correct.
I edited my question to make it look like a problem instead of a show case
"However, the rod on the right exerts a positive force on the test charge. This is because the force direction from the rod and the displacement are pointing at the same direction"
I think it's negative force, as the charge is negative and negative charge repel negative.
"b) Greater than. -PE = KE. If electric potential energy is negative, then KE must be positive. Thus, greater velocity"
I think is same,the time spent on decelerating the charge is equal to the time spent on accelerating the charge,so end velocity=same.
Others I think assuming those info u gave're correct and based on my limited AS-lv knowledge and stuff are correct.
It doesn't matter if you define force to be positive or negative. You can set the coordinate system whichever way you want. But if the direction of force and the displacement traveled are the same, then work is positive. In this case, force and distanced traveled are the same, I think. If I am wrong, can anyone correct it for me?
I thought that as long as there is constant force, there is always constant acceleration, unless force is changing at some point...
C'mon, can someone answer my question please. I want to understand the problem rather than getting an answer. Any help will be appreciated.
  • · Replies 22 ·
