Electric resistance in the truncated rotating cone
25 replies · 4K views
ciso112
Homogeneous body with the shape of a truncated rotating cone has a base shaped like a
circle. The radius of the lower base is R2 = 8 cm and radius of the upper base is R1 =
4 cm. The height h = 8 cm (see figure). Calculate the total electric
resistance between the base surfaces of the body, when made of a material of
resistivity ρ = 4*10 ^(-2) Ohm*m. Assume that during the transport of electric charge
through the body volume, the current density changes.
see the picture
idea:
triple integration..one through the height...and the remaining ones through the radius and the perimeter...but does this take into account the changing of the radius at different heights?
Only a single integration is needed. Hint: thin circular disks.
Write a general expression for any intermediate radius in terms of R1,R2 and h. Use it for calculation of resistance of thin circular discs and integrate along proper path.
hm, this gives me the integral of PI*r^2 with boundries of R2 and R1...?
This is not what you need to integrate. The entire truncated cone can be thought of as made of many thin slices (circular disks). Each disk will have a small resistance dR that will depend on the radius and thickness of the disk. These resistances are in "series", so the total resistance is the sum (or integral) of the individual resistances.
As you can see the resistances are in series, your limits of integration will be from 0 to h. Try writing a general expression for intermediate radius in terms of R1, R2 and h.
cnh1995 said:
intermediate radius
could you clarify this term pls, not even google helped me
am I getting closer? dR = (PI*r^2*dh)/dI where I is electric current
The radius varies from x=0 to x=h. You need to find a general expression for radius at a distance x in terms of R1, R2 and h. That's what I meant by intermediate radius. Limits of x will be from 0 to h when you'll integrate.
There's no need to involve current.
R=ρ*l/A.. For a small disc at a distance x from the leftmost end, what is the length and area of cross section in terms of x?
In the figure below, you see a disk located at position x along the axis of the cone. The disk has a thickness dx and an area A(x) which depends on x. ( You will need to express A(x) explicitly in terms of the position x.) How would you express the resistance, dR, of the disk in terms of A(x) and dx?
Radius varies linearly with x. At x=0, r=R1 and at x=h, r=R2. Using this data, can you write a general expression for r in terms of x?
The concept behind seems to be clear, the second thing is to write it down...what about: ...l (radius of a given element) = r1 + ((r2-r1)/h)*x
ciso112 said:
The concept behind seems to be clear, the second thing is to write it down...what about: l (radius of a given element) = R1 + (R2-R1 +dh) ...where dh could be x
It's like a straight line passing through (0, R1) and (h, R2). How will you write r as a function of x from this data? It is in the form r=ax+b.. Now a and b can be found using known quantities R1, R2 and h.
r1 + ((r2-r1)/h)*x could it be?
dR = ρ * (r1 + (((r2-r1)/h)*x)/dA) ?
Right!
cnh1995 said:
Right!
great, I thank you so much!
now all I need is to express dA and then I can turn to mathematics, yes?
what about, dA = PI*r^2*dx?
The expression you got is for radius r.
R=ρ*l/A..
Look at Tsny's image carefully. You need to express dR in terms of dx and A(x)..
You now know radius r as a function of x. For a small disc of resistance dR, what is the thickness and cross sectional area in terms of x? Once you get that expression, all you need to do is integrate it between 0 to h.
I am not sure what "l" is, I think this is tha last think that needs clarification
if "l" is the width, then: dR = RO*(dx/PI*r^2) where r = r1 + ((r2-r1)/h)*x ?
There you go!:smile:
wow, words can hardly express the gratitude I feel towards you guys. Please, have all my likes
...and a video of a gopro camera set on a rocket which flies to space :D
