Electricity, Direction of Charge Problem
Bound
Some background: This was a quiz I recently had in which I lost a few points for missing an "x & y component" for one of the directions.
My thinking is that because the problem was not actually set up with a specified order of charges there are a few different answers you could get.
I intend to bring this up with the teacher, but thought I'd see what you guys have to say as well.
Three charges are arranged in the shape of an equilateral triangle. (Note- no diagram is given)
The charge magnitudes are as follows:
q1=+4*10-6C, q2=-6.5*10-6C, q3=+2.1*10-6C
The distance between each charge is 2m
Calculate the electric force on q3.
F = (kq1q2) / d2
I set my triangle up as: (see attached picture)
Calculated force of 1 on 3:
F = .0189 N
X-component of F13:
Fx=(.0189)(sin30)
=.00945 N
Y-component of F13:
Fy=(.0189)(cos30)
=.0163676801 N
*Marked Correct*
Calculated force of 2 on 3:
F = -.0307125 N
*Marked incorrect for not separating into x & y components*
Would this not be correct though? The way I set my triangle up has 2 on a straight horizontal line across from 3!
My further work is just adding up all of the components of everything for a final answer of:
Net Force on q3 = .0268 N @ 37.6deg SofW
Thanks for any help!
F = (kq1q2) / d2
F = .0189 N
X-component of F13:
Fx=(.0189)(sin30)
=.00945 N
Y-component of F13:
Fy=(.0189)(cos30)
=.0163676801 N
*Marked Correct*
F = -.0307125 N
You must always specify units and direction for any vector quantities, otherwise points will be deducted. It's not enough to assume that unspecified directions imply a direction along the positive x-axis (or Easterly), unless you so specify in your work.
So would I just have had to specify xx.xx N [0deg. E] to be correct?
Or are you implying that there is some arbitrary angle in which that force can be broken into a y-component, if so I don't have the first idea on how to find that angle.
That would work.
All planar vectors have two components, even if one of them happens to have a zero magnitude. When one of the components happens to be zero you can drop it so long as you've specified the direction for the remaining component. It would not be incorrect to include the zero magnitude component as, for example, 0.00 N [North].
In your work for the other forces you explicitly broke them out as Fx and Fy. You could have done the same for F23 and written
For F23:
Fx = xx.xx N
Fy = 0.00 N
