Electromagnet attracting permas
  • Thread starter Thread starter Shortyski13
    Electromagnet
When a weak electromagnet is placed near a small permanent magnet, both poles of the permanent magnet can be attracted to the same side of the electromagnet due to the interaction with the electromagnet's iron core. The stronger permanent magnet may induce its own magnetic field in the iron core, leading to this behavior even when the electromagnet is weak. This phenomenon suggests that the electromagnet's effectiveness is influenced by the strength of the permanent magnet. Additionally, there is curiosity about the possibility of creating an electromagnet with a non-ferrous core while still achieving a defined magnetic field and reasonable strength. Overall, the discussion highlights the complexities of magnetic interactions between electromagnets and permanent magnets.
Shortyski13
I wired a quick weak electromagnet. How come when I put a small permanent magnet close to it, both sides of the permanent magnet (north and south) are attracted to the same side of the electromagnet?
Hi and welcome
What you saw was a bit hard to understand. If, indeed, the electromagnet was weak and the small permanent magnet was comparatively stronger then your result was interesting but not too uncommon.
The result you got, implies to me that the electromagnet must have an Iron core and your small permanent magnet was inducing its own field in the electromagnet (iron) core. It was attracting it just the same as it would if the electromagnet were turned off (possibly with a bit less force in on orientation).
This is what I was thinking was happening. Which leads me to another question, if that is the case: can I make an electromagnet with a non -ferrous core and still have a defined magnetic field shape and still some strength to it?
I think that would be ok as long as you could make a strong enough electromagnet without an iron core.
Thread 'Motional EMF in Faraday disc, co-rotating magnet axial mean flux'
So here is the motional EMF formula. Now I understand the standard Faraday paradox that an axis symmetric field source (like a speaker motor ring magnet) has a magnetic field that is frame invariant under rotation around axis of symmetry. The field is static whether you rotate the magnet or not. So far so good. What puzzles me is this , there is a term average magnetic flux or "azimuthal mean" , this term describes the average magnetic field through the area swept by the rotating Faraday...
It may be shown from the equations of electromagnetism, by James Clerk Maxwell in the 1860’s, that the speed of light in the vacuum of free space is related to electric permittivity (ϵ) and magnetic permeability (μ) by the equation: c=1/√( μ ϵ ) . This value is a constant for the vacuum of free space and is independent of the motion of the observer. It was this fact, in part, that led Albert Einstein to Special Relativity.
