Electromagnet attracting permas
  • Thread starter Thread starter Shortyski13
    Electromagnet
When a weak electromagnet is placed near a small permanent magnet, both poles of the permanent magnet can be attracted to the same side of the electromagnet due to the interaction with the electromagnet's iron core. The stronger permanent magnet may induce its own magnetic field in the iron core, leading to this behavior even when the electromagnet is weak. This phenomenon suggests that the electromagnet's effectiveness is influenced by the strength of the permanent magnet. Additionally, there is curiosity about the possibility of creating an electromagnet with a non-ferrous core while still achieving a defined magnetic field and reasonable strength. Overall, the discussion highlights the complexities of magnetic interactions between electromagnets and permanent magnets.
Shortyski13
I wired a quick weak electromagnet. How come when I put a small permanent magnet close to it, both sides of the permanent magnet (north and south) are attracted to the same side of the electromagnet?
Hi and welcome
What you saw was a bit hard to understand. If, indeed, the electromagnet was weak and the small permanent magnet was comparatively stronger then your result was interesting but not too uncommon.
The result you got, implies to me that the electromagnet must have an Iron core and your small permanent magnet was inducing its own field in the electromagnet (iron) core. It was attracting it just the same as it would if the electromagnet were turned off (possibly with a bit less force in on orientation).
This is what I was thinking was happening. Which leads me to another question, if that is the case: can I make an electromagnet with a non -ferrous core and still have a defined magnetic field shape and still some strength to it?
I think that would be ok as long as you could make a strong enough electromagnet without an iron core.
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
