How can I increase the strength and volume of my electromagnetic speaker?
  • Thread starter Thread starter viks505
    Electromagnetic
This discussion centers on the challenges of replacing permanent magnets in speakers with electromagnets to enhance sound volume and strength. The user experimented with a soft iron rod, 28 AWG enameled copper wire, and a 12 V 500 mAh DC power supply but failed to achieve the desired electromagnetic strength. Contributors highlighted that permanent magnets provide superior field strength necessary for loud volume, and suggested that using AC signals to power the electromagnet could lead to poor frequency response and require a more powerful amplifier.
  • Understanding of electromagnetic principles in audio applications
  • Familiarity with speaker design and components
  • Knowledge of AC and DC power supply characteristics
  • Basic concepts of inductance and frequency response in audio systems
  • Research the properties of neodymium magnets in speaker design
  • Explore the use of AC signals in electromagnet applications
  • Investigate the impact of self-inductance on audio frequency response
  • Learn about high-power amplifier requirements for electromagnet-driven speakers
Audio engineers, speaker designers, hobbyists experimenting with speaker modifications, and anyone interested in the physics of sound production.
viks505
Well I have tried a different approach to make speakers.
Normally speakers contain permanent magnets for producing sound using the property of electromagnetism when electric signals are passed through a coil kept in the magnetic field of Permanent Magnet. (ref: How Speakers Work frm How Stuff works).
now what i have tried to do here is replaced the permanent magnet of the speaker with an electromagnet.
keeping the principal of speaker in mind i have even left the minor air gap between the core and coil (of electromagnet) for letting the coil with electric signals vibrate in the influence of magnetic field producing sound.
the basic idea while performing this was to reduce the weight of speaker along with obtaining difference in sound just by changing the strength of electromagnet.
i have used a soft iron rod of 0.75" dia., 28 awg enameled copper wire, 12 V 500 mAh DC power supply for electromagnet.
the problem being faced here is i am unable to get the similar strength of electromagnet as that of Permanent magnet of the speaker. though i have achieved the sound objective but volume remains very low.
even increase in no. of turns of the coil and changing source to 12 V 3 Amps DC has not solved the problem.
what am i missing, should i go for any different approach in order to increase the field and sound volume
In the 1940's I disassembled pre-war (WW II) (vacuum tube) AM radio sets with electromagnet speakers. The electromagnet was a dc filter coil for the B+ (high voltage) dc supply...
Bob S
I believe that's why permanent magnets are used in speakers -- that's the best way to get the very high short-range fields needed to get loud volume.
I don't think you will achieve the field strength of modern speaker magnets easily with an electromagnet. There is also the 'green' issue of power consumption as you will need lots of current-turns which will involve higher voltages etc.. It could be real 'steam radio'!
Bob S
What is known as a hum bucker.
Has anyone ever tried just using the same AC power signal coming to the speaker voice coil to power the electromagnet? You would have to plan for the correct resistance of course.
It would have to be the opposite phase of the coil of course which would make them repel and attract.
I believe you would get the amps required and only be using them when necessary rather than trying to power an electromagnet the whole time.
Basically it would work like an AC motor.
The magnets in speakers are permanent magnets, not electromagnets.
If you tried to excite the Electromagnet with the audio signal then the self inductance would only allow significant current at the low frequencies. That would make the frequency response very glubby, not to mention the relative phase shift between the current in the voice coil and the varying magnetic field. Then, of course, you'd need a hugely powerful amplifier, compared with what's needed for a standard permanent magnet speaker. Hardly a serious engineering proposition.
If God had intended us to do it that way he'd never have given us neodymium magnets.
I understand that. I was initially proposing to replace the permanent magnet with an electromagnet.
The answer below is great.
Great answer. I didn't even think about the inductance. Doop!
  • · Replies 37 ·
  • · Replies 17 ·
10K
12K
