Electromagnets: Insulation concern
The discussion centers on the construction of an electromagnet using a 1" diameter iron bar and D-cell batteries. The original poster inquired about the thickness of wire insulation, proposing to use 5mm copper wire with nylon insulation and a PVC jacket. Experts in the forum emphasized that using wire with thick insulation limits the number of turns possible, which directly affects the magnetic field strength. They recommended using 28AWG or smaller magnet wire with thin enamel insulation to optimize current flow and magnetic field generation.
  • Understanding of electromagnet principles and magnetic fields
  • Familiarity with wire gauge measurements (AWG)
  • Knowledge of electrical resistance and power supply characteristics
  • Experience with insulation types and their impact on electrical applications
  • Research the properties and applications of 28AWG magnet wire
  • Learn about the relationship between wire gauge and current carrying capacity
  • Investigate the effects of insulation thickness on electromagnetic efficiency
  • Explore methods for calculating resistive loads in electromagnet designs
Electronics enthusiasts, hobbyists constructing electromagnets, and engineers focused on optimizing electromagnetic devices.
Mindstormed
I'm constructing an typical electromagnet, wrapping coil x amount of times around a 1" diameter iron bar, and getting power from 'D' cell batteries. My question is how thick can the wire's insulation & jacket be?
Most of the examples I've seen used a nail, with 22-26 gauge copper or magnet wire that has a thin coat of enamel insulation. I'm proposing to use a 5mm (4 gauge I suppose) copper core wire, with nylon insulation and a PVC jacket. The total thickness of the wire is about the size of a pen. Would this type of wire generate a magnetic field?
Thanks.
Magnet wire has thin insulation on purpose, so you can stack as many turns as possible in a finite volume. Using wire with thick insulation will limit how effectively you will be able to turn current into magnetic force.
And why are you using such a thick metal wire? You would only use that for very high current carrying capacity, and you are not going to get anything like that with D-cell batteries providing the power.
So it's possible with a higher current? I'm looking to get at least two layers in.
To maximize your power transfer, you would want to match the resistive load of the coils to the source power supply. Do you know the output resistance of a D battery cell (and how it varies with discharge)? Almost certainly the best wire for you to use will be 28AWG or less, and preferably smaller and with magnet wire insulation.
Why is it important to have the copper wire insulated? Does insulation increase it's effectiveness?
Because it's running electricity.
The wire has to be insulated because, otherwise, the turns of wire could contact the turns of wire next to them.
So, the electric current would go between the wires and not around the coil.
The magnetic field is generated when current flows in many turns of wire.
Short circuiting the turns of wire would result in reduced or no magnetic field.
You need some insulation but not a lot because electromagnetics operate primarily as "current" devices with very low resistance so the voltage drop between adjacent turns (or even extreme ends) tends to be very small, which means the electric field the insulation must endure is not generally close to the insulator's dielectric strength. This is why a thin layer of enamel (paint) insulation is generally enough for most applications.
As an example, I've working with an electromagnet that runs 100 amperes and it only uses enamel insulations: the end-to-end resistance is only 0.030 ohms so the total voltage drop is still only 3 volts. Enamel insulation is more than enough.
As a side note, the wire has square cross-section because it packs the cross-sectional coil area better than round wire. Just a factoid of interest.
  • · Replies 27 ·
  • · Replies 37 ·
10K
