Electromagnets suffer from temp coefficients?
Electromagnets experience changes in resistance due to temperature variations, requiring higher voltage to maintain power. The ferrous metal used in electromagnets has a Curie temperature, which affects its magnetic properties. The permeability (mu) of the metal varies with temperature, being highest at mid-range temperatures and decreasing at extremes. Once the Curie temperature is reached, the electromagnet's effectiveness is significantly diminished. Iron's Curie point is approximately 700°C, which is beyond typical operational limits for many applications.
Cliff_J
Ok, so the wire used in an electromagnet will likely have its resistance affected by a temp change on a PTC and thus require a higher voltage to maintain power, simple enough. But will an electromagnet also suffer temp coefficients for induction and coercivity and have a currie temp too?
The ferrous metal of the electromagnet will have a Curie temperature, and the mu of the metal will have a temperature coefficient. Usually the mu is highest at mid-temperature, and lower at the hot and cold extremes. But once you hit the Curie temperature, ker-plop.
Thanks. With proper spelling I now see that iron has a Curie point of around 700C which is well beyond what I need.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
