Electron in a parallel plate capacitor - finding plate's magnitude
4 replies · 14K views · last reply
vaxopy
The drawing shows an electron entering the lower left side of a parallel plate capacitor and exiting at the upper right side. The initial speed of the electron is 7.00×106 m/s. The capacitor is 2.00 cm long, and its plates are separated by 0.150 cm. Assume that the electric field between the plates is uniform everywhere and find its magnitude.
See the picture attached..
I don't really know how to start this.. (at all).
would i try to find the centripetal force of the electron, and let that equal to the plates strength?
  • Diagram of an electron entering at the lower left between two parallel plates, with a dashed curved path bending upward to the top right; top plate marked with plus signs, bottom plate with minus signs, labeled 2.00 cm across and 0.150 cm separation.
michaelw said:
but how do you find its acceleration?
Using kinematics. There is a uniform acceleration in the vertical direction; constant speed in the horizontal. Find the acceleration, then the force, then the field.
