Electron oscillation frequency, what pushes them away?
In summary, electrons oscillate at their natural frequency due to the force of attraction (Coulomb law) from the nucleus. However, there is no force pushing them away. The oscillation of the electron cloud is responsible for the production of light in a similar frequency to the incoming electromagnetic wave. This concept applies to the reflection of light from a surface, but not to the emission of light when the electron transitions between energy levels.
Thierry12
25
Electron oscillate at their natural frequency. I know the force that brings them back is a force of attractrion (Coulomb law) but what pushes them away?
Er.. what is an electron's "natural frequency"?
Zz.
I guess you mean within an atom... then, it's a rather tricky question! Two possible answers:
(1) Short story: "centrifugal force". Along with Coulomb attraction create an "effective potential" for the radial variable which has a minimum and, around it, a well which looks like a harmonic oscillator well for low amplitudes.
(2) You mean the frequency of rotation around the nucleus. Then, nothing to do with harmonic oscillators.
I have always found that it is almost "futile" to guess at a question that has been posed in such a vague manner. Even if one were to assume that this particular question meant either an electron in an atom, or the deBroglie wave, it still doesn't define a "natural frequency" because in both cases, there can be more than just ONE "frequency" involved.
It is best that one waits till the OP comes back and put SOME effort into explaining the question.
Zz.
Sorry for the lack of precisions, let me try again: correct me if I am wrong but i picture the oscillation of the eletron as an harmonic oscillation, and i was wondering what would the force constant be/represent? (If I am completely wrong please tell me, I am not very advanced in physics).
ty
What do you mean by the oscillation of the electron?
Sorry to tell you, but you are completely wrong.
Could you tell me how it works generaly the electron oscillation ( no need to be precise but just the general idea )
ty
If we examine the theory of Rayleigh scattering in air, the conventional theory has the electrons in atoms being displaced from the nuclei center by the E field vector of the incoming visible light photons, and pulled back by the nuclear charge center (hence dipole oscillation). The oscillation is in phase with, and at the frequency of, the incoming radiation, hence the driving force frequency. The atoms re-radiate in the plane perpendicular to the E vector, which is why Rayleigh scattering (blue sky light) at 90 degrees is polarized.
Is your question "how does the electron move within an atom"?
Many times, the problem is that the question one is asking is the thing that is wrong. Are you thinking that the electron in an atom is oscillating radially back and forward? Where did you get the idea that "Electron oscillate at their natural frequency"? You have to be more explicit when you ask things if you are a beginner.
That is the explanation given in Classical Electrodynamics, this is the Quantum Physics forum;-)
Im trying to understand how an electromagnetic wave makes charges oscillate which makes em radiation similar to the original wave. I was trying to find out about oscillation at its base to understand how it really happens.
Ty for the help btw, really appreciate it!
You really need to sit down and think through your question, because if you look at the very beginning of this thread, you mentioned no such thing, but you somehow expected us to be able to read your mind and figure out what you meant. It took SEVERAL posts to actually extract something resembling a clarification of what you actually are looking for. Oy vey!
Zz.
Sorry about that, i will try to be more precise next time
when the electrons are bound to the nucleus the light produced is exactly the same as when they are free (as in a conductor) only the amount of light produced is different. instead of total reflection from the surface (like a mirror) you only get partial reflection (like from the surface of water).
in this way of looking at things we imagine that the electron is bound to the nucleus by some kind of spring or something. this might explain the reflection of light from a surface and this would indeed result in a 'natural frequency'.
however this idea has absolutely nothing to do with light emitted when the electron transitions from one energy level to another (even though you can associate a certain frequency with each orbital. the frequency of emitted light being equal to the differece of the frequencies of the orbitals that the electron transitions between)
the answer is 'nothing'. the electron cloud sits directly over the nucleus.
When asking about the natural oscillation of electrons, it is possible that Thierry12 had heard of “Zitterbewegung”.
See: http://en.wikipedia.org/wiki/Zitterbewegung for a great explanation of the “trembling motion” of electrons discovered by Schroedinger and Dirac.
For more advanced reading, see: arXiv:0810.2186v1 “Catching the Zitterbewegung”
Of course this is not for Classical Physics, it belongs in the Quantum Physics threads.
Bobbywhy
1. What is electron oscillation frequency?
Electron oscillation frequency is the rate at which an electron moves back and forth in a periodic motion around a fixed point.
2. Why do electrons oscillate?
Electrons oscillate due to the presence of an external force or field that causes them to move back and forth. This can be in the form of an applied electric or magnetic field.
3. How is electron oscillation frequency related to the size of the oscillation?
The electron oscillation frequency is directly proportional to the size of the oscillation. This means that the larger the oscillation, the higher the frequency.
4. What pushes electrons away during oscillation?
During electron oscillation, the electrons are pushed away from their original position by the external force or field acting on them. This force can be from an electric field or the repulsive force between two like charges.
5. What factors affect the electron oscillation frequency?
The electron oscillation frequency can be affected by factors such as the strength of the external force, the mass of the electron, and the properties of the medium the electron is oscillating in (such as temperature or density).
  • Electromagnetism
  • Electromagnetism
