Electron traveling between two plates. Electric Fields?
The problem involves an electron traveling between two charged plates and its deflection due to electric fields. The original poster poses multiple parts regarding the deflection of both electrons and protons traveling in various horizontal directions.
  • The original poster expresses uncertainty about the direction of deflection for protons and electrons in different orientations, questioning the implications of their charges and the terminology used for directions.
  • Some participants suggest considering the implications of the electric field based on the deflection of the electron and how that might apply to other particles.
  • There is a discussion about the meaning of "horizontally north" and whether it implies a perpendicular direction to previously mentioned orientations.
The discussion is ongoing, with participants exploring the implications of electric fields on particle motion and clarifying terminology. Some guidance has been offered regarding the relationship between the direction of deflection and the charge of the particles, but no consensus has been reached.
The original poster indicates confusion about the concepts involved and the terminology used, particularly regarding the definition of "horizontally north." There is also a lack of clarity on how different directions affect the problem.
MaryCate22
An electron traveling horizontally east passes between two horizontal, oppositely charged plates and is deflected downward.
Part A: Passing through the same space between the plates, in what direction (if any) a proton traveling horizontally east would be deflected?
Part B: Passing through the same space between the plates, in what direction (if any) an electron traveling horizontally west would be deflected?
Part C: Passing through the same space between the plates, in what direction (if any) a proton traveling horizontally west would be deflected?
Part D: Passing through the same space between the plates, in what direction (if any) a proton traveling horizontally north would be deflected?
Answer choices for all parts :
a) It wouldn't be deflected.
b) It would be deflected vertically downward.
c) It would be deflected vertically upward.
Not sure. This question is labeled under "Electric Fields and Forces."
My gut tells me that the proton traveling horizontally east would be deflected upward, opposite of the electron. I have no clue how traveling west changes the problem. And as far as part D, what does horizontally north even mean? I'm really lost on this problem. I'm not sure with what concepts to approach it.
If the electron gets deflected downward, what should that tell you about the plate on top of it and the plate below it? After figuring this out, apply it to the other particles.
As for horizontally north ... not sure about the terminology either. Maybe it just means directly north on some horizontal plane. It may just imply the direction is perpendicular to the previously mentioned direction? I'd want to hear what someone else thinks about the term though.
You stand on the ground, with a compass in your hand. You find the directions to East, North, South, West. Holding a ball in our hand, you throw it horizontally Eastward. It will fall while moving to East (It deflects downward).
Now throw the ball horizontally toward North. Will it deflect downward again?
Yes?
MaryCate22 said:
Yes?
Of course ...Push a ball on a table in either direction, it will fall downward after leaving the table.
I think what ehild is getting at is that horizontal means 0 z component.
  • · Replies 58 ·
  • · Replies 16 ·
