Electron Wave Behavior in Transistors - Yashtir Gopee
The discussion revolves around the wave behavior of electrons in transistors, exploring concepts of wave-particle duality, the size of electrons, and the implications for transistor miniaturization. Participants also touch on the relevance of Moore's Law and alternative computing technologies.
  • Yashtir Gopee questions when electrons behave as waves in transistors, referencing their dual nature as particles and waves.
  • Some participants suggest that the behavior of electrons as waves or particles depends on measurement methods rather than a fixed state.
  • There is a claim regarding the size of electrons, with one participant asserting it is less than 10^-22 meters, challenging the notion of an electron having a defined radius.
  • Questions are raised about whether electrons oscillate and the implications of their displacement for transistor size reduction.
  • Discussion includes references to current transistor sizes, with a mention of 90 nm for CMOS transistors and the potential for individual electron confinement in smaller transistors.
  • Moore's Law is mentioned as an observation of industry trends, with a suggestion to consider alternatives like 3D ICs, DNA computing, or quantum computing for future advancements.
  • One participant emphasizes the quantum nature of electrons, stating that terms like size and spin may not hold the expected meanings in quantum mechanics.
Participants express differing views on the nature of electrons and their behavior, with no consensus on the implications for transistor miniaturization or the future of computing technologies.
Limitations in understanding arise from the complex nature of quantum mechanics, particularly regarding the definitions and implications of terms like "size" and "oscillation" in relation to electrons.
Yashtir Gopee
Hello All,
From my A'Level knowledge of Physics, an electron is both a particle and a wave but not both at the same time.
I would like to know when does an electron behave as a wave (if it does) in a transistor?
Thanks
Yashtir Gopee
The electron has a radius of 10^-16m. Does it oscillate and how much is its displacement?
Actually I would like to know till how much can we reduce the size of a transistor (assuming we get the appropriate materials and environment for the current limitations).
You are misunderstanding what you've read. The best measurements we have say that whatever the electron's radius is, it's something less than ##10^{-22}## meters. This is consistent with it being a point particle of size zero (to the extent that "size" is even a meaningful concept for a quantum object such as an electron).
There are indeed quantum mechanical limits to how small a transistor can be made, but to understand them you need to understand the quantum mechanical description of electrons.
When you ask about the radius and the displacement and whether the electron oscillates, you're thinking in terms the popular English-language meaning of the word "particle", as if the electron is some sort of little tiny object like a ball with an electric charge. However, the word "particle" has a completely different meaning in quantum mechanics (it's a historical accident that we use the word "particle" to describe these quantum objects), so none of this thinking applies.
The literature talks about sizes on the order 90 nm for a CMOS transistor:
http://www.monolithic3d.com/blog/is-there-a-fundamental-limit-to-miniaturizing-cmos-transistors1
and on wikipedia there's a discussion on electron size:
Confinement of individual electrons[edit]
Individual electrons can now be easily confined in ultra small (L = 20 nm, W = 20 nm) CMOS transistors operated at cryogenic temperature over a range of −269 °C (4 K) to about −258 °C (15 K).[65] The electron wavefunction spreads in a semiconductor lattice and negligibly interacts with the valence band electrons, so it can be treated in the single particle formalism, by replacing its mass with the effective mass tensor.
https://en.wikipedia.org/wiki/Electron
and then there's Moore's law which is really an observation of industry trends:
https://en.wikipedia.org/wiki/Moore's_law
Welcome to PhysicsForums, Yashtir!
The electron does not oscillate in the normal sense of the word. True, it has a property call "spin" but that is a misleading word. Please keep in mind that the electron is a quantum particle. That means that it operates by the Rules of Quantum Mechanics and quantum field theory. The descriptive words do not accurately describe what is best described mathematically.
So words like size and spin do not have meaning as you would expect. There is no theoretical lower limit on the size of the electron, so it is often described as a point particle (as already stated by Nugatory and others). It is just as accurate (and as meaningless) to state that a free electron is the size of the universe. Again, it is a quantum particle and all quantum particles have similar descriptive problems.
This is why Nugatory says there are limits to transistor size reduction. Within materials, there are field effects to consider which are well outside the "normal" properties of individual particles.
Maybe I'm going a little off-topic now,
Do you guys think continuing Moore's Law is worth it or should we consider alternatives such as 3D IC, DNA Computing(if we want to continue with classical computing) or Quantum Computing?
I wrote an article 2 years back. Have a look through it http://www.yashtechblog.me/the-future-of-computing/
If it is innacurrate, please tell me.
Indeed you are. This thread is closed.
  • · Replies 36 ·
10K
  • · Replies 39 ·
  • · Replies 28 ·
  • · Replies 26 ·
