Electrons in a TV tube accelerated from rest.
Electrons in a TV tube are accelerated from rest through a 25-kV potential difference, resulting in a kinetic energy of 4 x 10^-16 J per electron. The correct calculation for the speed of the electrons upon hitting the screen is derived using the formula K = (1/2)mv^2, leading to a final speed of 9.37 x 10^7 m/s. A common error in the calculations was using an incorrect voltage value of 2.5 x 10^3 J/C instead of the correct 25 x 10^3 J/C. This mistake resulted in an initial incorrect speed calculation of 2.9 x 10^7 m/s.
  • Understanding of kinetic energy (K = (1/2)mv^2)
  • Familiarity with electric potential (voltage) and its units (J/C)
  • Basic knowledge of electron charge (1.6 x 10^-19 C)
  • Newtonian mechanics principles
  • Review the derivation of kinetic energy from electric potential energy
  • Learn about the relationship between voltage, energy, and charge
  • Study the implications of unit conversions in physics calculations
  • Explore the behavior of electrons in electric fields
Students studying physics, particularly those focusing on electromagnetism and mechanics, as well as educators looking for practical examples of energy conversion in electric fields.
_F_
Electrons in a TV tube are accelerated from rest through a 25-kV potential difference. With what speed do they hit the TV?
V = 25*10^3 J/C
I'm not really sure here. I'm thinking you have to use Newtonian mechanics somewhere here.
So,
x(t) = (1/2)(a_x)t^2 + (v_0)t +x_0
(v_f)^2 = (v_0)^2 + 2(a_x)d
You also need electomagnetic equations.
So,
delta-V = delta-U/q = -E*delta-r
This is where I have trouble. I don't even know where to start. Any pointers in the right direction (that aren't too vague!) would greatly be appreciated.
Welcome to PF!
V = 25*10^3 J/C
Hi _F_! Welcome to PF! :smile:
Hint: volts = energy/charge (as you can see from the J/C units).
So what KE does each electron have after going through a 25kV potential difference? :smile:
Okay, so K = (1/2)mv^2
We have volts in J/C, so to get a value of just energy would we multiply V*q?
If so:
V*q = (2.5*10^3 J/C)(1.6*10^-19 C) = 4*10^-16 J.
So K = 4*10^-16 J,
Then
K/[(1/2)m] = v^2 => (4*10^-16 J)/[(1/2)(9.1*10^-31 kg) = 8.79*10^14 J/kg
So v^2 = 8.79*10^14 J/kg
Then, v = sqrt(8.79*10^14 J/kg) = 2.9*10^7 m/s
But this is not what the back of my book says. In the back, the answer is 9.37*10^7 m/s.
If so:
So K = 4*10^-16 J,
Then
Hi _F_! :smile:
Hint: check your units … you're out by a factor of √10. :wink:
tiny-tim said:
Hi _F_! :smile:
J = kg*m^2/s^2
V = [J/C]
Vq = [J]
K = [J]
v^2 = 2K/m = [m^2/s^2]
v = [m/s]
Where did I go wrong?
_F_ said:
J = kg*m^2/s^2
V = [J/C]
Vq = [J]
K = [J]
v = [m/s]
V is given to be 25*10^3 J/C. You used 2.5*10^3.
Ack! Thanks. Such a stupid mistake. :rolleyes:
  • · Replies 49 ·
  • · Replies 23 ·
