Electrons in uniform electric field
herbert1
http://dl.dropbox.com/u/305636/yeephysics.jpg
If that doesn't work, the problem states:
A pair of parallel metal plates, 100mm long and a distance of 20mm apart are set up in an evacuated tube as shown. A potential difference is applied to the plates, creating an electric field of 56 NC down 9the page). A beam of cathode rays, where all the particles are traveling at 4x10^6 m/s, enters the region between the plates from the left, at a point midway between the plates. (Neglect effects due to gravity).
I need help with part D
Which asks:
What is the increase in the kinetic energy of the cathode ray particle in traveling the length of the plates.
E = F/q
F = ma
v^2 = u^2 + 2as (where v = final vel. u = initial, s = displacement)
I thought about using Work = Vq, as work has to be the change in kinetic energy? But the length of the places threw me off.
So I used F = Eq into Eq = ma, a = Eq/m
Then v^2 = u^2 + 2(Eq/m)*0.1 to find the velocity of the particle at the end. Then i found the kinetic energy of the particle at the start and end using 1/2mv^2 and subtracted them and got 4.4856x10^-19 J. But I am not sure if this is right?
Thanks for your time.
The electric field accelerates the electrons in the direction perpendicular to the plates. The normal velocity component gained is proportional to the time the electrons spend between the plates.
ehild
