Why Is My Calculation of Electrostatic Equilibrium Incorrect?
The forum discussion centers on the calculation of electrostatic equilibrium involving three charges, specifically how to determine the position of the third charge (q3) relative to two other charges (q1 and q2). The user initially set the electrostatic forces equal but encountered difficulties due to unknown variables, particularly the magnitude of q3. Key insights include the necessity of positioning q3 to the left of the origin and the importance of understanding Coulomb's Law in this context. The discussion emphasizes that the total force on q3 must equal zero for equilibrium, regardless of q3's magnitude.
  • Coulomb's Law
  • Concept of electrostatic forces
  • Understanding of electric fields
  • Basic algebra for solving equations
  • Study the concept of electric fields and their equilibrium conditions
  • Learn how to apply Coulomb's Law in multi-charge systems
  • Explore graphical methods for visualizing electrostatic forces
  • Investigate the implications of charge magnitudes on electrostatic equilibrium
Students and educators in physics, particularly those focusing on electrostatics, as well as anyone seeking to deepen their understanding of charge interactions and equilibrium conditions in electrostatic systems.
cs44167
A charge of 2.0 microcoulombs is positioned at (0,0) and a charge of -6.0 microcoulombs is positioned at (3,0). Where must a third charge be placed in order to be in electrostatic equilibrium?
Electrostatic Force = kq1q2/d^2
I set the electrostatic force exerted by the object at (0,0) and (3,0) equal to each other, dividing out k and q2. I was left with q1/d^2 for both terms and substituted in the given charges for each object. I then replaced d^2 for the object at (0,0) with “x^2” and d^2 for the object at (3,0) with “(3-x)^2”. I got an answer of (1.098, 0) which made sense that it would be somewhere left of 1.50, but was incorrect.
Any helpers in where I went wrong? Thanks.
In which directions do the forces go?
So the third charge would have to be to the left of the origin, correct?
Then you would have negative-positive-negative.
From there I’m struggling with Coulomb’s Law because we don’t know the magnitude of the charge on the third object. I have q3q1/x^2 =q1q2/3^2 but we don’t know x or q3.
Make sure to draw a diagram. Try positioning this third charge at a distance ##d## to the left of the origin, and then draw on the forces. I don't believe you need to know ##q_{3}##.
You can look at this two ways. You can take any charge ##q_3## and try to make the total force on ##q_3## due to ##q_1## and ##q_2## equal to zero. If ##q_3## doesn't cancel out, then you have a serious conceptual or mathematical problem!
Or, you can look for a position where the electric field due to ##q_1## and ##q_2## is zero. Then, clearly, the value of ##q_3## is irrelevant.
Can you write down in words what ##\frac{q_3q_1}{x^2}## is supposed to be? It is the force of object [which] on object [which other]?
Can you write down in words what ##\frac{q_3q_2}{3^2}## is supposed to be? It is the force of object [which] on object [which other]?
Which object are you trying to find the force on?
  • · Replies 32 ·
11K
