Elevator Free Fall: Understanding the Physics and Sensation of a Cut Cable
The discussion clarifies that when an elevator accelerates downward at 9.8 m/s², it experiences the same sensation as when its cable is cut, resulting in free fall. Both scenarios lead to weightlessness for the occupants inside the elevator. The key point is that the elevator's acceleration must match gravitational acceleration for the sensations to be identical, regardless of whether the cable is intact or slack. This understanding is crucial for grasping the principles of free fall and gravitational forces.
  • Understanding of Newton's laws of motion
  • Basic knowledge of gravitational acceleration (9.8 m/s²)
  • Familiarity with concepts of free body diagrams
  • Knowledge of forces acting on objects in motion
  • Study the principles of free fall and weightlessness in physics
  • Learn how to construct and analyze free body diagrams
  • Explore the effects of acceleration in different gravitational fields
  • Investigate the relationship between tension in cables and gravitational forces
This discussion is beneficial for physics students, educators, and anyone interested in understanding the dynamics of motion and forces, particularly in scenarios involving free fall and gravitational effects.
blueblast
Hi guys,
I know this is a really simple question, but I'm just making sure I have this concept down:
Scenario 1. An elevator accelerates down at 9.8m/s^2.
Scenario 2. The elevator cable is cut.
If someone is inside an elevator, scenarios 1 and 2 would feel exactly the same to them, correct?
Thanks,
blueblast
Assuming no other forces on the elevator aside from the cables and the Earth's gravity then you are correct.
If the elevator accelerates downward at 9.8 m/s^2 then it must be getting no support from its cables. Whether this is because the cables go slack or because they have been cut is pretty much irrelevant.
Is the 9.8m/s2 plus gravity, because if the cable is cut it gets 9.8m/s2 acceleration, anyway... because if you accelerate an elevator at 9.8m/s2 in space would be the same as cutting the cable on Earth.
No. Cutting the cable on Earth puts the elevator in free fall: objects inside the elevator will float weightless. Accelerating at 1g in space is the same as the elevator sitting still on the surface of the earth.
So,
(normal force) - (force accelerating elevator down) - (gravity) = - (gravity)
What normal force?
What force accelerating the elevator down, other than gravity?
And why have -gravity on both sides of the equality?
The "force accelerating elevator down" is what is moving the elevator down at an acceleration of 9.8 m/s^2, while the cable is still attached.
I have gravity on both sides since I was comparison Scenario 1 and Scenario 2.
Am I understanding this concept completely wrong?
Gravity alone would make the elevator accelerate downward at 9.8 m/s^2. Are you saying that there is a second force in addition to gravity that is pulling the elevator downward at a total of 19.6 m/s^2?
It is not clear what question you are trying to ask yet.
blueblast said:
So,
Show us your free body diagram for this scenario.
Okay, let me reiterate this whole thing:
So let's say an elevator is hanging by a cable. It is not accelerating. Although there is gravity, the cable supports the weight of the entire elevator(this part I know I'm right for sure). Now let's say this elevator was lowered at an acceleration of 9.8 m/s^2. Since this is the same acceleration as gravity(free fall), would this have the same effect as just cutting the cable of the elevator?
As I said in #2, a slack cable (required to achieve this downward acceleration) and a cut cable have the same effect.
There is other "downward force" involved. And no unidentified "normal force" involved. However, if you want to toss in additional forces on the elevator that all sum to zero, that works too.
Under free fall conditions, the elevator AND the person will be accelerating at the same rate. IF you just 'accelerate the elevator' out in space then the passenger would be left behind and end up against the ceiling of the box - just as if the elevator were suspended (upside down) on Earth. The passenger would not feel weightless.
Okay, thanks everyone!
  • · Replies 22 ·
  • · Replies 38 ·
  • · Replies 31 ·
