Superposition of Plane EM Waves Using Complex Notation
The discussion focuses on the superposition of plane electromagnetic (EM) waves using complex notation. The incident electric field is represented as $$\vec{E}_I = E_0 e^{i(ky - wt - \frac{\pi}{2})} \hat{z}$$ and the reflected wave as $$\vec{E}_R = E_0 e^{i(-ky - wt - \frac{\pi}{2})} \hat{z}$$. The summation of these fields leads to the expression $$-2E_0 \cos(ky) \sin(wt) \hat{z}$$, confirming the application of trigonometric identities and complex exponentials in wave analysis. The solution is validated by the community, affirming the correctness of the approach.
  • Understanding of electromagnetic wave theory
  • Familiarity with complex notation in physics
  • Knowledge of trigonometric identities
  • Basic proficiency in mathematical manipulation of exponential functions
  • Study the derivation of trigonometric identities using complex exponentials
  • Explore the application of Fourier analysis in wave superposition
  • Learn about the principles of wave interference and diffraction
  • Investigate the role of phase shifts in electromagnetic wave propagation
Students and professionals in physics, particularly those focusing on electromagnetism, wave mechanics, and mathematical methods in physics.
WWCY
I have a simple problem relating to the superposition of plane EM waves that I'd to try out using complex notation. Could anyone run through the work to see if my understanding is right?
Many thanks in advance!
The incident E bit of the wave is
$$\vec{E}_I = E_0 \sin(ky - wt) \hat{z} = E_0 \cos(ky - wt - \frac{\pi}{2}) \hat{z}$$
The wave propagating opposite is
$$\vec{E}_R = E_0 \sin(-ky - wt) \hat{z} = E_0 \cos(-ky - wt - \frac{\pi}{2}) \hat{z}$$
I left out the B since it was really the same thing.
First I generalise them to complex notation
$$\vec{\tilde{E}}_I = E_0 e^{i(ky - wt - \frac{\pi}{2})} \hat{z} $$
$$\vec{\tilde{E}}_R = E_0 e^{i(-ky - wt - \frac{\pi}{2})} \hat{z} $$
Then summing them,
$$E_0 \big [ (e^{iky} + e^{-iky})e^{-i(wt + \frac{\pi}{2})} \big] \hat{z} = E_0 \big [ (2\cos(ky))e^{-i(wt + \frac{\pi}{2})} \big] \hat{z}$$
Finally I take the real part
$$E_0 \big [ (2\cos(ky)) \cos(wt + \frac{\pi}{2}) \big] \hat{z} = -2E_0 \cos(ky) \sin(wt) \hat{z}$$
Does this look right?
There is a trig identity that says $$\sin a+\sin b=2\sin \left(\frac{a+b}{2} \right) \cos\left(\frac{a-b}{2} \right).$$ Your expression checks out. Note: This identity can be proven quite readily using complex exponentials, which is what you did.
Thank you!
  • · Replies 21 ·
