Solving for EMF: Potential Differences with R1 = 4 x R2 | Homework Question
  • Thread starter Thread starter yamugushi
    Circuit Emf
To solve for the potential difference in terms of EMF (E) with R1 = 4 x R2, the relationship between the resistances must be established. The initial values of R1 and R2 were simplified to 3/4 and 1/4, but further calculations revealed inconsistencies. By substituting R1 into the equations, the current can be expressed as a function of E and R2. Using Ohm's law (V = IR), the EMF across R2 can then be derived solely in terms of E after algebraic simplification. This approach allows for a clearer understanding of the potential differences in the circuit.
yamugushi
If R1 = 4 x R2 then what are the values of the potential difference in terms of the EMF, E?
I have R1 = 3/4, and R2 = 1/4 but that seems a bit simplistic, then I tried plugging it into equations and got completely different answers.
R=V/I (?)
EMF=v1 +v2
First I simply put it as 1/4 and 3/4, then I plugged it into the equations:
v=IR
v1=1(4) =4
v2=1(1) =1
EMF=v1 + v2 = 5
R2 = 1.25, R1 = 5
Solve the current, I. Express this interim result as a function of E, R1 and R2.
Since you know that R1 = 4 x R2, you can now express the current solely as function of E and R2 (since R1 goes away after the substitution).
Now that you know the current, using V = IR, find the EMF (i.e. voltage) across R2. You should be able to express it solely as a function of E (after some algebraic simplification).
  • · Replies 22 ·
  • · Replies 18 ·
