EMF/internal resistance question
  • Thread starter Thread starter PennyGirl
    Resistance
8 replies · 4K views
PennyGirl
http://session.masteringphysics.com/problemAsset/1042319/4/YF-25-68.jpg"
Above is a picture of the circuit!
The question is: "What is the terminal voltage of the 4.00-V battery?"
I=V/R
V_ab = E - I*r
So first, I calculated the current in the loop...
the voltage is 8v-4v = 4v
and the total resistance is...6+.5+9+.5+8 = 24 ohms
so I = V/R =4/24 = 1/6
from this...
V_ab = 4v - (1/6)*(.5) = 3.917v
however, the program I am using (masteringphysics) responded "Not quite. Check through your calculations; you may have made a rounding error or used the wrong number of significant figures" when I entered this in...
I have no idea where I'm going wrong because in a later question, I used the same method and got the right answer...help!
Thanks!
you may have used the wrong number of significant figures
no...I double checked that
how many significant figures are there in 4.00 V
hom many in 3.917 V
hom many in 3.917 V
I entered the value twice, once as 3.917 and the second time as 3.92...both times it had the same error message.
Sorry, I didn't see this at once. What is the direction of the current? And what is the direction
of the potential difference across the upper 0.50 ohm resistance?
the direction of the current is clockwise...but I'm not sure what you mean by the direction of the potential difference...the voltage is higher on the right side (in the picture) and lower on the left side...
If the current goes clockwise, it will make the left side of the top 0.50 ohm resistance more positive to the right side. Therefore the potential difference has to be added to the 4.00V of the battery.
If the 8V voltage source is replaced by a wire the current would go in the other direction and the potential difference across the internal resistance of the top battery would have to be subtracted from the EMF of the battery, but it has to be added here.
Thanks a lot! that worked and it does make sense...I was just plugging numbers into the formulas that I have and not really thinking about the problem lol.
Thanks again!
