Can an Enclosed Superconducting Loop Generate Electromotive Force?
An enclosed superconducting wire loop subjected to a time-dependent magnetic field can induce electromotive force according to Faraday's law. However, due to the superconductor's vanishing electrical resistance, a potential difference cannot be sustained. The superconductor generates a magnetic field that opposes the external field, leading to cancellation within the loop. As equilibrium is reached, the electric field inside the superconductor becomes zero, resulting in no potential difference. This phenomenon illustrates the unique behavior of superconductors in response to changing magnetic fields.
ofirg
Hi,
If I take an enclosed superconducting wire loop, and apply a time dependent magnetic field in the space enclosed by the wire ( and therefore a time dependent magnetic flux) , this should induce electromotive force ( according to faraday's law). However any potential difference should not be possible due to the vanishing electrical resistance. I understand that a superconductor acts to cancel any magetic field within the superconductor, but here the magnetic field can be in the middle of the space enclosed by the loop, distanced from the superconductor itself.
Any help would be appreciated
The current in the loop generates a mag field opposite to the external mag per law of Lenz. Equilibrium is reached when cancellation occurs not only inside the conductor, but in the interior of the loop as well. The plane formed by the loop receives an incident mag field, time varying. A Lorentz force moves the electrons in the conductor around the loop. A mag field surrounds this conductor. Law of Lenz describes this field as having a polarity opposite to the external mag field. Use the right hand rule, and the internal mag field extends into the interior of the loop.
Eventually the fields will cancel. Since J = sigma*E, per Ohm's law, sigma is infinite for a superconductor, so E has to be zero, likewise potential is zero. Does this help?
Claude
Yes,
Thanks allot.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 39 ·
