Energy conservation in a FLRW spacetime
andrewkirk
Insights Author
Consequences of Energy conservation in a FLRW spacetime
This entry uses the local energy conservation law to derive an equation that can be used, together with the Einstein field equation, to derive Friedman's equations for the dynamics of a homogeneous, isotropic universe.
The energy conservation rule is ##{T^{0b}}_{;b}=0##.
We want to use this to get information about the equation of state
We use FLRW coordinates for this, in which the metric tensor components are all zero except for:
\begin{align*}
g_{00}&=-1, g_{11}=\frac{R^2}{1-kr^2}, g_{22}=R^2r^2, g_{33}=R^2r^2sin^2\theta\\
\end{align*}
Here ##R## is the scale factor, which depends only on ##t##.
The stress-energy tensor is T##=(\rho+p)\vec{v}\otimes\vec{v}+p##g-1 where ##\vec{v}## is the average four-velocity of the particles of the fluid which, in the FLRW coordinates, is ##(1,0,0,0)##, because of the isotropy assumption.
The representation of T in FLRW coordinates is a diagonal matrix with elements:
##T^{00}=\rho##, ##T^{11}=p \frac{1-kr^2}{R^2}##, ##T^{22}=\frac{p}{R^2r^2}##, ##T^{33}= \frac{p}{R^2r^2sin^2\theta}##
Now we write ##0={T^{0b}}_{;b}={T^{0b}}_{,b}+T^{ab}\Gamma^0_{ab}+T^{a0}\Gamma^b_{ab}##
We calculate the three terms in turn.
First, we have ##{T^{0b}}_{,b}={T^{00}}_{,0}=\frac{\partial\rho}{\partial t} = \dot{\rho}## because T inherits a diagonal nature in the FLRW coordinates from ##\vec{v}\otimes\vec{v}## and g.
For the next step we use
\begin{align*}
\Gamma^0{ab}&=\frac{1}{2}g^{0s}(g_{as,b}+g_{bs,a}-g_{ab,s})\\
&=\frac{1}{2}g^{00}(g_{a0,b}+g_{b0,a}-g_{ab,0})\\
&=\frac{1}{2}g^{00}(g_{00,b}+g_{00,a}-\delta^a_b g_{aa,0})\\
&=\frac{1}{2}\delta^a_b g_{aa,0}\\
\end{align*}
since ##g^{00}## is constant at ##-1##. Hence the second term is:
\begin{align*}
T^{ab}\Gamma^0_{ab}&=T^{ab}\frac{1}{2}\delta^a_b g_{aa,0}\\
&=\frac{1}{2}T^{aa} g_{aa,0}\\
&=\frac{1}{2}\Big(\rho(g_{00,0})+p \frac{1-kr^2}{R^2}g_{11,0}+\frac{p}{R^2r^2}g_{22,0}+\frac{p}{R^2r^2sin^2\theta}g_{33,0}\Big)\\
&=\frac{1}{2}\Big(0+p \frac{1-kr^2}{R^2}\frac{\partial}{\partial t}(\frac{R^2}{1-kr^2}) +\frac{p}{R^2r^2}\frac{\partial}{\partial t}(R^2r^2)+\frac{p}{R^2r^2sin^2\theta}\frac{\partial}{\partial t}(R^2r^2sin^2\theta)\Big)\\
&=3p\frac{\dot{R}}{R}
\end{align*}The third term is
\begin{align*}
T^{a0}\Gamma^b_{ab}&=T^{00}\Gamma^b_{0b}\\
&=\frac{\rho}{2}g^{bs}(g_{0s,b}+g_{bs,0}-g_{0b,s})\\
&=\frac{\rho}{2}g^{bb}(g_{0b,b}+g_{bb,0}-g_{0b,b})\\
&=\frac{\rho}{2}g^{bb}g_{bb,0}\\
&=\frac{\rho}{2}\Big(0+\frac{1-kr^2}{R^2}\frac{\partial}{\partial t}(\frac{R^2}{1-kr^2})+\frac{1}{R^2r^2}\frac{\partial}{\partial t}(R^2r^2)+\frac{1}{R^2r^2sin^2\theta}\frac{\partial}{\partial t}(R^2r^2sin^2\theta)\Big)\\
&=3\rho\frac{\dot{R}}{R}
\end{align*}
Putting the three terms together, we have:
\begin{align*}
{\rho}+3(\rho+p)\frac{\dot{R}}{R}=0\\
\end{align*}
We can express this in a manner that better reflects the relationship of work and energy by considering the rate of change of energy in a co-moving volume:
\begin{align*}
\frac{d}{dt}(\rho R^3)&= 3\rho R^2\dot{R}+\dot{\rho}R^3 =R^3\Big(\dot{\rho}+3\rho\frac{\dot{R}}{R}\Big) = -3p R^3\frac{\dot{R}}{R}
=-3p\dot{R}R^2=-p\frac{d}{dt}(R^3)\\
&\textrm{In summary:}\\
\frac{d}{dt}(\rho R^3)&=-p\frac{d}{dt}(R^3)\\
\end{align*}
The left-hand side is the increase in energy in the co-moving volume as it expands and the rightmost formula is the negative of the work done in the expansion.
In the current universe, in which most mass-energy is matter, and it is very sparsely distributed on average, average pressure ##p## is low compared to ##\rho## and can be ignored, so we get the approximation ##\frac{d}{dt}(\rho R^3)=0## in the matter-dominated phase of the universe.
In the early universe, there was not much matter and such particles as there were would be traveling very fast. Hence the equation of state for a photon gas or a highly relativistic gas applies, which is ##p=\frac{1}{3}\rho##. Inserting that in the above equation we get:
\begin{align*}
\frac{d}{dt}(\rho R^3)= -\frac{1}{3}\rho\frac{d}{dt}(R^3)\\
\end{align*}
Multiply by ##R## and collect on one side to get:
\begin{align*}
0&=R\frac{d}{dt}(\rho R^3)+R\frac{1}{3}\rho\frac{d}{dt}(R^3)\\
&=R\frac{d}{dt}(\rho R^3)+R\frac{1}{3}\rho(3R^2)\dot{R}\\
&=R\frac{d}{dt}(\rho R^3)+(\rho R^3)\dot{R}=\frac{d}{dt}(\rho R^4)\\
\end{align*}
So, in the early, energy-dominated era, we have:
\begin{align*}
\frac{d}{dt}(\rho R^4)&=0\\
\end{align*}
V.361.
Likes fresh_42
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
According to the General Theory of Relativity, time does not pass on a black hole, which means that processes they don't work either. As the object becomes heavier, the speed of matter falling on it for an observer on Earth will first increase, and then slow down, due to the effect of time dilation. And then it will stop altogether. As a result, we will not get a black hole, since the critical mass will not be reached. Although the object will continue to attract matter, it will not be a...
