Energy Density with a Dielectric
The discussion revolves around the concept of energy density in the context of a dielectric material within a capacitor. Participants are exploring how the electric field behaves when a dielectric is introduced and the implications for energy density calculations.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants are questioning the correct application of formulas related to electric fields and energy density, particularly in the presence of a dielectric. There is a discussion on whether the electric field remains constant and how to properly calculate energy density using different approaches.
Some participants have provided guidance on the applicability of certain equations and suggested alternative methods for calculating energy density. There is an ongoing exploration of different interpretations regarding the behavior of the electric field and the use of specific formulas.
Participants are navigating assumptions about the conditions under which the capacitor is charged and the dielectric is added, as well as the proper use of permittivity values in their calculations.
racecar_
Two parallel plates, having a vacuum in between them, are separated by d=0.01 m apart and are connected to a battery maintaining 9V between the plates and a charge of Q0 magnitude on each plate. The separation between the plates is then raised to 2d, the battery voltage is increased to 18V, and a dielectric is added with dielectric constant 2. What is the energy density difference after the addition of the dielectric?
energy density = (1/2)εE^2
I am confused about how the electric field changes in this problem - is E' = E/Ke=E/2? Is E = V/d a correct usage?
When I solve it this way, the answer is incorrect:
change in energy density = (1/2)ε(E'2- E2) = (1/2)ε(E2/4 - E2) = (1/2)ε(-3/4)(V/2d)2.
What am I doing wrong? Thanks.
This equation does not apply in your situation. This equation would be valid if, after charging the capacitor, you disconnect the capacitor from the battery and then add the dielectric.
Yes. This is generally valid for any parallel plate capacitor.
The obvious approach is to calculate the stored energy in each case and divide by the volume.
So the electric field will stay the same? For the equation energy density = (1/2)εE^2, what changes then?
Yeah, I think it's a better approach. In what situations should I use finding the stored energy and dividing the volume rather than (1/2)εE^2, and vice versa? Thanks.
Either approach should work if you know what you’re doing. Here you made a key mistake by using ε for both vacuum and dielectric between the plates instead of for only the dielectric.
Yes.
Following up a little on @kuruman's post. The energy density of an electric field in a vacuum is ## \frac1 2 \varepsilon_0 E^2##. This expression is modified for an electric field inside a dielectric. Have you covered this in your course?
If not, then use the approach of finding the stored energy divided by the volume.
  • · Replies 39 ·
