Energy radiated by an electron
  • Context: Graduate
  • Thread starter Thread starter vipinpsharma
    Electron Energy
The discussion revolves around the behavior of electrons in atoms, particularly focusing on their movement, energy states, and the implications of zero-point energy (ZPE). Participants explore concepts from quantum mechanics, including the nature of electron orbits, energy transitions, and the role of ZPE in atomic stability and energy absorption.
  • Some participants question whether electrons move in orbits around the nucleus or occupy orbitals defined by probability distributions.
  • It is suggested that if electrons were to revolve around the nucleus, they would radiate energy due to their charge, raising questions about the sustainability of such motion.
  • Some argue that electrons do not "fall" into the nucleus because they are not in classical orbits, and their energy states prevent collapse.
  • Participants discuss the process of energy radiation when electrons transition to lower energy states, with some noting that electromagnetic radiation is the mechanism for energy loss.
  • There is a debate regarding the interpretation of zero-point energy, with some asserting it is not a source of usable energy while others suggest it may interact with vacuum energy.
  • Some contributions reference the Heisenberg uncertainty principle as a basis for understanding electron behavior and ZPE.
  • Participants express differing views on the implications of vacuum energy and its relationship to zero-point energy, with some citing it as controversial in certain contexts.
  • There are references to renormalization in quantum field theory and its implications for understanding vacuum energy and zero-point energy.
Participants generally do not reach consensus on the nature of electron movement, the role of zero-point energy, or the implications of vacuum energy. Multiple competing views remain, particularly regarding the interpretation and significance of these concepts in quantum mechanics.
Limitations include varying interpretations of quantum mechanics, the dependence on definitions of energy states, and unresolved questions about the nature of vacuum energy and its implications in physics.
vipinpsharma
Do electrons really move around the nucleus in an orbit? Or we cannot say that because of quantum rules which say that we can only locate a electron at a position with certain probability? If it does revolve, then:
1) where is the energy coming to make the electron go around the nucleus?
2) if electron revolves, and since it is a charge particle, it will create magnetic field and in effect will eventually radiate with certain energy? How long can it really last?
No, they do not occupy an orbit like a planet does around a star. The correct term is an "orbital". Each electron can only occupy a certain energy state. In this state the electron has a probability of being found in certain locations. The electron cannot "fall" down into the nucleus because it isn't actually moving around it.
"If we assume for example that the electrons in the atom are stationary, there exists no stable arrangement of the electrons which would preven the electrons from falling into the nuclues under the influence of coulomb attraction"
Quantum Physics of Atoms, Molecules, Solids, Nuclei, and Particles pp. 95
I thought zero point energy kept the electron from collapsing into the nucleus.
Thanks, that helps.
So, when an electron jumps to a lower energy orbit, why does it radiate energy in electromagnetic waves?
From my understanding the electrons wavefunction gives it a range of areas it can occupy yet doesn't require it to actually move around the nucleus. Additionally electrons can only occupy energy levels that adhere to specific rules. They can't collapse because that would require them to merge with protons to form neutrons, and that requires energy.
vipinpsharma said:
Thanks, that helps.
The difference in energy between the two levels is given off as EM radiation. Without losing energy the electron could not occupy the lower energy level. There simply isn't another way for it to lose energy other than EM radiation as far as I know, though I'm not 100% sure on that.
Its my understanding that electrons have to mantain a physical energy to stay in that energy level, when they jump, the frequency of the EM radiation released is equal to the energy of the photon divided by planks constant. So it obeys classical theory in this sense. Bohr believed electrons didn't release EM energy when orbiting, but I assumed when they mentioned zero-point energy later in the book, that this was the electron abrsorbed energy keeping it from colliding with the atom, hence the energy released orbiting, was equal to the energy absorbed through ZPE keeping it from colliding, but I haven't checked this yet and it's been a year sense I've taken modern physics.
I'm not sure what you mean by "maintain a physical energy". Each level has its own unique amount of energy that an electron has while it occupies it. This requires nothing to maintain.
Bohr's orignal model of the atom was incomplete and it required full Quantum Mechanics to explain why electrons did not radiate energy as they orbit the nucleus. The answer was that they don't orbit and don't radiate energy.
Zero point energy is simply the lowest energy state of a system I believe. It is not a source of energy to my knowledge. Electrons most definitely do not constantly radiate energy when they are in their orbital.
By physical energy I mean
"Since the atomic electron must have a total energy exactly equal to the energy of one of the allowed energy states, the atom can only absorb discrete amounts of energy from the incedent electromagnetic radiation"
Quantum Physics of Atoms, Molecules, Solids, Nuclei, and Particles pp. 103
I think ZPE is based more on the Heisenberg uncertainty principle that since you can never know the simultanous position and momentum of an electron it is always moving.
Some people believe that ZPE is absorbed through vacuum energy. Vacuum energy relies on background radiation from virtual particles, which is based on pertubation theory. Pertubation theory goes back to the Heisenberg uncertianty principle.
From wikipedia:
Zero-point energy is the lowest possible energy that a quantum mechanical physical system may have; it is the energy of its ground state. All quantum mechanical systems undergo fluctuations even in their ground state and have an associated zero-point energy, a consequence of their wave-like nature. The uncertainty principle requires every physical system to have a zero-point energy greater than the minimum of its classical potential well, even at absolute zero
Since this is the ground state, the minimum energy state, there is no energy available for work. It is not a source of energy able to be absorbed to my knowledge.
Yes, that is correct.
If ZPE is source of energy, that's something that is still being debated since it relies on vacuum energy which still encounters controversy.
To my knowledge it does not encounter controversy in real science, only in psuedoscience and with people who claim to make free energy machines. Zero point energy is very well defined by Quantum Mechanics.
"The theory considers vacuum to implicitly have the same properties as a particle, such as spin or polarization in the case of light, energy, and so on. According to the theory, most of these properties cancel out on average leaving the vacuum empty in the literal sense of the word. One important exception, however, is the vacuum energy or the vacuum expectation value of the energy. The quantization of a simple harmonic oscillator requires the lowest possible energy, or zero-point energy of such an oscillator to be:
Summing over all possible oscillators at all points in space gives an infinite quantity. To remove this infinity, one may argue that only differences in energy are physically measurable, much as the concept of potential energy has been treated in classical mechanics for centuries. This argument is the underpinning of the theory of renormalization. In all practical calculations, this is how the infinity is handled."
http://en.wikipedia.org/wiki/Vacuum_energy
When feynman discusses the renormalization factor, he refers to it as as magic, becuase they simply put in zeros to make the equation work. To me, it still seams controversial.
In any case:
"Vacuum energy is the zero-point energy of all the fields in space, which in the Standard Model includes the electromagnetic field, other gauge fields, fermionic fields, and the Higgs field. It is the energy of the vacuum, which in quantum field theory is defined not as empty space but as the ground state of the fields. In cosmology, the vacuum energy is one possible explanation for the cosmological constant.[3] A related term is zero-point field, which is the lowest energy state of a particular field.[4]"
http://en.wikipedia.org/wiki/Zero-point_energy
"Vacuum energy is an underlying background energy that exists in space even when the space is devoid of matter (free space). The concept of vacuum energy has been deduced from the concept of virtual particles."
My logic was that ZPE absorbs vacuum energy from the background radiation from virtual particles. How much is absorbed was determined from the renormalization factor which was made to match experiments.
You cannot absorb energy from a minimum state. It cannot go any lower. And virtual particles would have to become real particles in order to give up any energy, which only happens in exceptional circumstances. Even in processes that may result in virtual particles becoming real, such as hawking radiation, the energy is not taken from the vacuum.
Here's how I came to the conlusion, I stand to be corrected, but it still seems logical to me.
"One of the most interesting aspects of vacuum energy (with or without mirrors) is that, calculated in quantum field theory, it is infinite! To some, this finding implies that the vacuum of space could be an enormous source of energy--called "zero point energy." "
http://www.scientificamerican.com/article.cfm?id=what-is-the-casimir-effec
"The Unruh temperature, derived by William Unruh in 1976, is the effective temperature experienced by a uniformly accelerating detector in a vacuum field."
http://en.wikipedia.org/wiki/Unruh_effect
Since the electron is accelerating around the atom (as orbiting bodies do), it would absorb vacuum energy due to the unruh effect.
Please read the FAQ sub-forum in the General Physics section.
Zz.
How does the electron "jump" from one energy state to another. Do they teleport or something (since the energy states is quantized)?
They simply acquire more energy by absorbing a photon, getting hit by another atom, etc. (Or lose energy to jump down) The "jump" simply means they absorb or give up energy and must occupy another energy level.
Yes, which is why renormalization is necessary. I don't think most people actually believe there is infinite energy, but more due to our own calculations. But that's just my opinion, I don't know for sure. From looking at zero point energy and related areas I simply don't see how you can get energy from a minimum energy state.
Zz.
Thanks for moving attention to the Q&A section, I have found much more to study.
Sorry, but my mind is full of things that in spite of a lot of study, I'm not yet finding solutions. I am progressing.
One question for consideration, is there a possibility of the electron continually extruding itself forward in it's own field force ? after an infusion of motion from any source.
Ludicrous maybe, but I do not find things that make for quick simple answers.
Thanks in advance for any answer.
Ron
I can't figure out what this might mean. Can you rephrase it in other words?
The same as the slightest motion of a conductor in a magnetic field producing a measurable voltage.
As I understand, the charge of an electron induced field is radial and if action/reaction law applies even at quantum levels, it seems the reaction would be directed back to the center point of the electron. I can't quite see it as a drag.
Hope that is better, it's hard to put the right words on a lot of my inside out thoughts.
Ron
Naty1 said:
An electron oribital is a probability function describing the behavior of electrons.
Some good pictures and more detail here:
http://en.wikipedia.org/wiki/Atomic_orbital
The old Rutherford Bohr model, particles revolving around a nucleus, and other representations are shown further down the page in the same article.
And be sure to scan the ORBITALS TABLE even further down:
http://en.wikipedia.org/wiki/Atomic_orbital#Orbitals_table
Thanks Naty1; jtbell; zapperz,
Much to study, it will take a little time and with holidays near, replies and question will be delayed.
I think "transitions between orbits" and "line spectra" appear to be areas to study and help me understand what I need to keep my curious thoughts accurate.
How electrons interact with each other, I need to understand how multiple electrons in one shell exist and maintain a continuity and is it harmony or chaotic.
At the quantum level, do I need to dissociate from my basic understanding of energy transfer through transformers ?
This quest of understanding hit a peak when I started looking into a toroidal transformer I would like to construct.
I will find an answer in my study, but a quick answer from anyone would be great. Is "line sprectra" the same as magnetic lines of force ?
Sorry if I have hijacked a thread, but my questions are related to the topic of where and how an electron is energized and the radiated force that gives to action/reaction.
Thanks
Hope everyone enjoys the holidays.
RonL
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 20 ·
  • · Replies 34 ·
