Energy release and levels during electron transition
In summary, the Hydrogen atom has an energy associated with electron transitions between the n=infinity and n=2 states. There are different Ryberg constants that can be used depending on the context of the equation.
ptownbro
60
Been looking but can't seem to find any comprehensive help on this.
In the Hydrogen atom, what energy is associated with these electron energy transitions:
a) N = infinity to N=2?
b) N = infinity to N=3?
c) N = 4 to N=2?
d) N = 5 to N=6?
I don't have any relevant formulas to start from or know where to start to give my attempt.
Any help appreciated.
thanks
There is no general formula and the question - as asked - has no definite answer.
Unless it is asked in the context of hydrogen like single electron Bohr atom, then it is trivial.
Sorry, I edited the question to make it more clearer (hopefully). It relates to the Hydrogen atom.
Have you heard names Bohr and Rydberg?
I have heard of Bohr and just read a little bit about Rydberg, but I can't seem to apply what I've read to this simple version. Also, I'm getting different constants than what was given in my daughter's textbook. Her's uses -2.18 x 10^-18, but online I see a 1.097 X 10^7 m^-1 constant.
I also added a more complicated question somewhat related o this, but I need to understand this basic part first I believe. All examples I've found use a given "Electron Volts" but my daughter's questions do not. So having hard time to translate what I've read to this.
Ev is just an energy unit, just like Joule. m-1 is not an energy unit, but it can be used to express the wavelength of the emitted photon, so in this case it is directly related to the energy. As it is wavelength that is easy to observe, we often use it in this context.
Could you maybe give me the question in a restated way as an example with the piece missing so we could get a hint of where to look?
Simply plug both n values (initial and final) into the Rydberg formula.
1/∞2 can be problematic - but is it much different from zero?
Likes ptownbro
Her teacher does't do a good job of explaining and leaves you to have to guess a lot. So, sorry I don't have a clearer question.
Anyway, if I understand this... Please confirm or correct where I'm wrong. =D
There different Ryberg constants that can be used depending on the context of the equation.
If related to the inverse of wavelength, you use R=1.097 X 10^7 m^-1
If related to the change in energy, you use R= -2.18 x 10^-18 J
In the question, it asked: In the Hydrogen atom, what energy is associated with these electron energy transitions?
Given, what I highlighted, I can infer then I must use the R=2.18 x 10^-18 J constant and the following formula:
ΔE = R ( 1 / n2^2 - 1 / n2^2)
Given what you said about infinity and going through her notes again, N=infinity is zero (or effectively ignored).
ΔE = R ( 1 / n2^2 ) = -2.18 x 10^-18 J * (1 / 4) = -0.545 x 10^-18 J
ΔE = R ( 1 / n2^2 ) = -2.18 x 10^-18 J * (1 / 9) = -0.242 x 10^-18 J
c) N = 4 to N=2?
ΔE = R ( 1 / n2^2 - 1 / n2^2) = -2.18 x 10^-18 J * (1 / 4 - 1 / 16) = -0.409 x 10^-18 J
d) N = 5 to N=6?
ΔE = R ( 1 / n2^2 - 1 / n2^2) = -2.18 x 10^-18 J * (1 / 36 - 1 / 25) = +0.027 x 10^-18 JDid I qualify for the Nobel prize?
Question doesn't ask about "energy change", but about "energy associated" with the transition. Thus I would report all values as positive.
Sign would make the difference if you were asked about the change of the energy of the electron (to go to a higher n it needs to absorb energy, so ΔEelectron > 0, if it goes to a lower n it emits energy, so the ΔEelectron < 0). Surroundings would have exactly the same change of energy, but with the opposite sign (technically it is the photon that is either absorbed from the surroundings, or emitted to the surroundings, but speaking about change of energy of a photon that didn't exist before emission is rather clumsy).
Likes ptownbro
Excellent. Thank you.
So to correct what I did in each above, I should use R=+2.18 x 10^-18 J in each (instead of R=-2.18 x 10^-18 J like I did)
Thanks again
1. What is energy release during electron transition?
Energy release during electron transition is the process in which an atom emits energy as an electron moves from a higher energy level to a lower energy level. This energy can be released in the form of light, heat, or other forms of electromagnetic radiation.
2. What is the relationship between electron transition and energy levels?
Electron transition refers to the movement of an electron from one energy level to another. The energy levels of an atom correspond to the amount of energy an electron has. As an electron moves from a higher energy level to a lower one, it releases energy in the form of light or other forms of electromagnetic radiation.
3. How does energy release during electron transition affect the properties of atoms?
The energy released during electron transition can affect the properties of atoms in several ways. It can change the color of the atom, alter its chemical reactivity, and affect its magnetic properties. These changes are a result of the movement of electrons and the amount of energy they release during transition.
4. Can energy release during electron transition be controlled?
Yes, the energy release during electron transition can be controlled in some cases. This is often done through the use of external energy sources, such as electricity or light. By supplying energy to the atom, the electrons can be excited to higher energy levels and then transition back down, releasing energy in a controlled manner.
5. How is energy release during electron transition related to the emission spectrum?
The emission spectrum is a visual representation of the specific wavelengths of light emitted by an atom as its electrons transition from higher energy levels to lower ones. The energy release during these transitions corresponds to specific wavelengths of light, creating a unique emission spectrum for each atom or molecule. Therefore, the energy release during electron transition is directly related to the emission spectrum of an atom or molecule.
  • Biology and Chemistry Homework Help
