Energy waves from impact in a solid
The discussion centers on measuring energy transfer from an impact into a solid and the propagation of waves from the epicenter using sensors. Key points include the conservation of energy principles and the relationship between wave strength, distance, and voltage measured by piezoelectric sensors. It is proposed that the energy at a specific distance from the wave source is proportional to the integral of voltage squared over time, multiplied by distance. The type of solid—whether ground or a vibrating object—affects the wave characteristics and sensor selection. Clarification on the setup and wave types is necessary for accurate analysis and measurement.
boltcrank
So I'm supposing a scenario where you have energy transfer into a solid and waves propagating out from the impact point and i want to measure the energy at different distances from the "epicenter" with sensors.
the relationships I've been pointed to are basically conservation of energy at the different distances and something along the lines of the double integral of the full circle of the wave and of the distance from the epicenter multiplied by things like wave strength and thickness, which can then be converted to an integral of wave speed over time.
then I've also been pointed out that with a piezoelectric sensor, that can further be converted to a measure of voltage squared integrated over time multiplied by a series of things, but then the distance from the wave source is pulled out as a constant.
my question involves this supposition then that the energy of a wave at a specific point and distance from the wave source will be proportional to the integral of the voltage squared over time, MULTIPLIED by the distance.
Is this indeed a valid relationship? so would it be correct to say that there is a distance and voltage where a sensor further away from a source than another might regardless measure a larger energy? what kind of relationship is this? because apparently its not the linear one i thought it would be.
First question is
Is this solid as in (a) solid ground or (b) a vibrating solid object such as a musical triangle or cymbals?
For (a) you need to look up seismic geophysical methods
and for (b) you need to look up mechanical vibarations and resonant excitation
i suppose it would be a mechanical vibration in a solid object like a block of wood or steel
Go on?
You really do need to describe your setup much more fully to get an answer.
Sensors can be velocity sensitive or acceleration sensitive.
Look here to learn about sensors
http://www.wilcoxon.com/knowdesk/TN16_Sensor%20Selection%20Guide.pdf
The entire solid object can be vibrating as a whole like my triangle example or a guitar string.
Or the waves can be like seismic waves in the Earth which only move a small part of the body at a time a they travel through it.
I think you mean this type but you need to confirm it.
Once you have confirmed that you need to specify the position and orientation of the transducer as the waves can be transverse ( up and down ) or longitudinal (side to side - backwards and forwards). These waves have different characteristics when they travel through large solid objects.
Or they may be composite surface waves which are different again.
the relationship i saw was for piezoelectric sensors with some capacitance that measure a voltage depending on the deformation of the sensor. if squeezed, a positive voltage, if squeezed harder ,a more positive voltage, if stretched, a negative voltage, etc
i imagine this would an assortment of seismic waves traveling thru the body. let's simplify it and say its an infinitely long plane of iron with finite thickness in a perfectly inelastic collision with a body significantly less massive then the infinite plane and a line of sensors at regular intervals from the site of the collision.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
