Energy: What will be the minimum ratio of m/M here
The problem involves two masses, m and M, connected by a string and affected by gravity. The objective is to determine the minimum ratio of m to M when the two blocks cross each other, as depicted in an accompanying image. The scenario requires understanding the forces and constraints acting on the masses as they move.
  • Participants discuss drawing free body diagrams (FBDs) and using trigonometric relationships to analyze the forces involved. Some express difficulty in forming equations and understanding the conditions under which the masses cross each other. Questions arise regarding the implications of the masses' relative sizes and the geometry of the setup.
The discussion is ongoing, with participants sharing their attempts and insights. Some suggest that energy considerations may play a significant role in understanding the problem, while others are exploring the implications of different mass ratios. There is no explicit consensus on the correct approach or interpretation of the problem yet.
Participants note potential ambiguities in the problem statement, such as the definition of "crossing" and whether the pulleys have a specified radius. Additionally, there are constraints related to the geometry of the system and the assumptions made about the motion of the masses.
  • #31
My sir just replied and our answer was indeed correct! Thank you very much https://www.physicsforums.com/members/delta.189563/ and Charles Link for your help. I really appreciate how I was led to the answer instead of it being given out to me. Thank you very much!
  • #32
Well thanks too but I didn't too much @Charles Link did all the job here.
The differential equations of motion for this problem would be like
for body of mass m:
$$mg-2T(t)\sin\theta_1(t)=L\frac{d^2\tan\theta_1(t)}{dt^2}$$
for body of mass M
$$2T(t)\sin\theta_2(t)-Mg=L\frac{d^2\tan\theta_2(t)}{dt^2}$$
##\theta_1(t)## is the angle made by the horizontal and the strings that are connected to body of mass m. ##\theta_2(t)## is the angle by the horizontal and the strings that are connected to body of mass M.
Need one more equation that relates ##\theta_1## and ##\theta_2## but I don't seem to find an obvious one. Also not sure if the tension T(t) is constant or time varying...
  • #33
@PhysicsBoi1908 I'm very glad we got the right answer. And thank you for posting the question. It really is one of the better ones we have encountered. At first sight, it almost looked like it was a problem with a very trivial solution of ## \frac{m}{M} \geq 1 ##, but it turned out to be very interesting. :smile::smile::smile:
  • #34
for body of mass m:
for body of mass M
Using energy equations, I think you can write an equation for the velocity of each mass as a function of y . The equation for each mass would have the form ## \frac{dy}{dt}=f(y) ##, which could be written as ## \frac{dy}{f(y)}=dt ##. Perhaps it even has a closed form solution. I haven't worked it yet to see. ## \\ ## Edit: Letting ## y ## the the distance that ## m ## moves, and ## y_1 ## the distance that ## M ## moves, and ## s ## the cable length from ## M ## to the pulley, we have ## s=3L-\sqrt{L^2+y^2} ##, and ## y_1=\sqrt{3}L-\sqrt{s^2-L^2} ##. ## \\ ## Finally, ## K.E.=\frac{1}{2}m(\frac{dy}{dt})^2+\frac{1}{2}M(\frac{dy_1}{dt})^2=mgy-Mgy_1 ##. Let me work it a couple more steps to see if I can get a single equation of ## \frac{dy}{dt}=f(y) ##. ## \\ ## Additional edit: Yes, ## y_1 ## can be expressed completely in terms of ## y ##, but it's not a simple expression. Thereby, we have ## g(\frac{dy}{dt})=f(y) ##, but ## f(y) ## is not a simple function, and ## g(\frac{dy}{dt}) ## is also not simple. ## \\ ## Additional edit: If anything at all useful comes out of this last bit of algebra and calculus, perhaps it is the almost obvious result that if ## \frac{dy}{dt}=0 ##, then ## \frac{dy_1}{dt}=0 ## as well.
  • #35
yes I knew from start that no matter how you decide to make the ODEs for this problem they would be non linear. @Charles Link the functions g and f you mention are not linear, they contain squares and square roots of their arguments if I understood correctly.
  • · Replies 30 ·
  • · Replies 22 ·
