Calculating Moments and Resolving Forces in Engineering Statics
The discussion revolves around resolving forces and calculating moments in a statics problem. The user successfully resolved a 10 kN force into components, leading to a resultant force of approximately 7.756 kN. They calculated moments for three forces but encountered confusion regarding the summation of moments and their relationship to the couple provided. A participant confirmed that the user should indeed add the calculated moment to the moment from the couple, while also pointing out an error in the user's moment calculation for one of the forces. Ultimately, the user corrected their mistake and arrived at the correct answer.
andrew.c
http://img512.imageshack.us/img512/2617/staticsquestion4.jpg
- Ability to resolve forces into components
- M = Fd
(a)
Resolve the force acting at an angle into components...
10kN force = -10cos50i - 10 sin 50 j kN
Therefore, resultant R becomes...
= (-10cos50)i + (15 - 3 - 10 sin 50)j kN
= -6.428i + 4.3396j kN
(with a magnitude of 7.756kN)
(b) This is where I get stuck.
I basically calculated the moments created by the individual elements of R,
F1 = 15kn force
F2 = 3kn force
F3 = vertical component 10kn force
and, because I am using the joint with the wall as an origin, the line of action of the horizontal component passes through my origin thus no moment.
M1 = 15*3 = 45kNm
M2 = -3*1.5 = -4.5kNm
M3 = (-10 sin 50)*9 = -68.944kNm
Sum of moments = 45 - 4.5 - 68.944 = -28.444kNm
and then I get stuck. Do you add the moment you've just found to the moment provide in the couple, then sub. back into M=Fd where F=R?
Help!
andrew.c: Nice work. The answer to the question in your last paragraph is yes. Also, notice a mistake in your M2 equation.
Yes, should use 4.5, not 1.5.
Thanks, I got the right answer!
