Entropy Equatio for a closed system
The discussion centers on the derivation of the entropy equation for a closed system, specifically addressing the formula for change in entropy (dS) under reversible conditions. The key equation presented is S_{T} = S_{0} + \int^{T}_{0} \frac{C_{p}dT}{T} + \sum \frac{\Delta H_{trans}}{T}, where the term \sum \frac{\Delta H_{trans}}{T} accounts for phase transitions. The user also explores the approximation of heat capacity (C_{p}) as constant, leading to the relation \int \frac{C_{P}dT}{T} \sim C_{P} \ln{T}. This highlights the importance of understanding phase transitions in entropy calculations.
  • Understanding of thermodynamic principles, particularly entropy and heat capacity.
  • Familiarity with calculus, specifically integration techniques.
  • Knowledge of phase transitions in thermodynamics.
  • Basic proficiency in LaTeX for mathematical expressions.
  • Study the derivation of the Clausius equation in thermodynamics.
  • Learn about phase transitions and their impact on thermodynamic properties.
  • Explore the concept of heat capacity in detail, including its temperature dependence.
  • Review integration techniques in calculus, focusing on logarithmic functions.
Students and professionals in thermodynamics, physicists, and engineers seeking to deepen their understanding of entropy and its calculations in closed systems.
Crazy Tosser
I must have already been banned for spamming threads.
But oh well.
You know how change in entropy dS of a closed system assuming reversibility of the processes = (\frac{dQ}{T})_{rev}=\frac{C_{p}dT}{T}
So when you try to find the actual entropy with respect to temperature, it's:
\displaystyle \int S_{T} = S_{0} + \int^{T}_{0} \C_{p}dT/T\
That's understandable. But that's my derivation. The text uses a slightly different formula:
S_{T} = S_{0} + \int^{T}_{0} \\frac{C_{p}dT}{T}\ + \sum \frac{\Delta H_{trans}}{T}
So my question 1 is: where did the \sum \frac{\Delta H_{trans}}{T} come from?
And my question 2 is:
if we say that heat capacity C_{p} is constant (it's not strictly constant, but with an approximation, we can call it a constant), we have:
\int \frac{C_{P}dT}{T} \sim C_{P} \int \frac{dT}{T}=
\sim C_{P} \ln{T}
Could the top eqn. be used as an approximation (part of an approximation, this is only a part of the equation)
As you can tell I am not that well-versed in Latex D=
Thanks
~Tosser
Science news on Phys.org
The ##\Delta H/T## terms come from the phase transitions from solid-to-liquid and from liquid-to-vapor (and any other phase transitions that occur, as, for example, from different crystal forms).
  • · Replies 19 ·
  • · Replies 21 ·
