Why Does Entropy Decrease in Adiabatic Compression?
  • Context: Graduate
  • Thread starter Thread starter enricfemi
    Entropy Gas
The discussion centers on the behavior of entropy during adiabatic processes, specifically addressing why entropy decreases during adiabatic compression. It is established that in a reversible adiabatic process involving an ideal gas, the change in entropy (ΔS) is zero, as derived from the equation ΔS = C_V ln(T_f/T_i) + R ln(V_f/V_i). The confusion arises from the distinction between adiabatic and isentropic processes; while adiabatic processes do not involve heat transfer, they can still result in changes in entropy if the process is not reversible. The example of free expansion illustrates that entropy increases due to pressure gradients, despite no heat exchange.
  • Understanding of classical thermodynamics principles
  • Familiarity with ideal gas laws and properties
  • Knowledge of reversible and irreversible processes
  • Basic mathematical skills for thermodynamic equations
  • Study the First Law of Thermodynamics and its implications for entropy changes
  • Learn about the concept of isentropic processes and their characteristics
  • Explore the Joule expansion and its effects on entropy in detail
  • Investigate the relationship between heat capacity ratios (C_p and C_V) and their impact on thermodynamic processes
Students of thermodynamics, physicists, engineers, and anyone interested in understanding the principles of entropy in adiabatic processes.
enricfemi
consider a adiabatic system, when we compressing the gas, i found its entropy is decreasing.
but it should increasing in adiabatic systems.
:confused:
Science news on Phys.org
Yes, it should increase or stay constant.
It's easy to tie yourself in knots about entropy and the Second Law. I do it all the time...
If you take an ideal gas cylinder, and expand or compress it "reversibly and adiabatically", then the change in the gas's entropy is exactly zero.
Why? Well, entropy is a function of state - if you know two other of the ideal gas's properties, e.g. its temperature T and volume V, you can calculate its entropy directly:
S = S_0 + C_V \ln T + R \ln V
This is a standard result from classical thermodynamics, and comes out of a form of the First Law. At high-ish temperatures, we can assume that the heat capacity at constant volume, C_V, is a constant. So, if we move from an initial state (T_i, V_i) to a final state (T_f, V_f), then the entropy of the gas will change by an amount \Delta S:
\Delta S = C_V \ln \left( \frac{T_f}{T_i} \right) + R \ln \left( \frac{V_f}{V_i} \right)
For a reversible adiabatic compression/expansion, there is a link between the initial and final temperatures and volumes (you can derive it from the First Law):
\frac{T_f}{T_i} = \left( \frac{V_f}{V_i} \right)^{1 - \gamma}
where \gamma = C_p / C_V is the ratio of heat capacities. Hence, the change in entropy as a result of the adiabatic compression is:
\quad = C_V \ln \left( \frac{V_f}{V_i} \right)^{1-\gamma} + R \ln \left( \frac{V_f}{V_i} \right)
\quad = C_V (1 - C_p/C_v) \ln \left( \frac{V_f}{V_i} \right) + R \ln \left( \frac{V_f}{V_i} \right)
\quad = (C_V - C_p + R) \ln \left( \frac{V_f}{V_i} \right)
and, as the heat capacities of an ideal gas are related by:
C_p = C_V + R
we see imediately that \Delta S = 0 regardless of whether the change was a compression or an expansion.
:confused:
adiabatic and isentropic are not necessarily the same thing. "Adiabatic" mean that no heat flows. This does not mean that the entropy necessarily remains constant. One can only say that
<br /> \delta Q \leq T\delta S<br />
the *equality* does not always hold--if the process is adiabatic *and* reversable than the entropy doesn't change.
The canonical example of an adiabatic but not-isentropic process is the free expansion of a thermally isolated gas. The entropy increases, but there is no change in energy and no heat flows.
thanks for all your guys! especially petrid!
but i am still confused. i can agree with that:
and in the textbook, it says that the free expansion is always entropy-increased.
i just not sure why the free expansion is not reversibly, and how can i calculate its increased entropy in compressing gas.
You can always calculate along the reversible path. Find out how much work would be extracted if the gas were expanded reversibly. Then re-inject that energy as heat, and calculate the increase in entropy.
Free expansion increases entropy because there is a gradient in pressure, and any process caused by a gradient (in material concentration, temperature, pressure, momentum, etc.) increases entropy. All the work that could have been extracted is instead dissipated in the system as heat in the turbulence during expansion.
In my first post, I described a reversible adiabatic expansion. A "free expansion" of an ideal gas (e.g. a Joule expansion) is quite different.
The procedure for a Joule expansion goes something like this:
  1. Start with a gas in a "room" of size V_i.
  2. "Next door" to this "room" is another "room" of volume (V_f - V_i) which is completely empty - it has no gas in.
  3. The two rooms are separated by a partition, so the gas cannot get through.
  4. Remove the partition.
  5. The gas expands very quickly to fill the whole box.
In A Joule expansion, if the gas is ideal, then its temperature does not change:
T_f = T_i
(Why? Because its internal energy U stays the same, and the internal energy of an ideal gas is a function of its temperature only U = U(T). So T also stays the same).
The entropy of the gas will change by \Delta S:
= R \ln \left( \frac{V_f}{V_i} \right)
because T_f / T_i = 1.
As you can see, this is very different from \Delta S = 0 in a reversible expansion!
:smile:
can i make it like this:
if we expand the ideal and adiabatic gas slowly enough, it is a reversible adiabatic expansion.
if we expand it more quickly, such as free expansion, its entropy increase.
  • · Replies 22 ·
  • · Replies 60 ·
10K
  • · Replies 135 ·
  • · Replies 20 ·
